Old 02-05-2005, 10:33 AM   #1
dawgmeat's Avatar
Talking Improvements on the 415ms that you would like to see on the 416, whenever that may be
It's that time again, Tamiya engineers are back to the ole' drawing board with their CAD designs just in time for next winter.
Things I would like to see
1. better alxe bearings
2. LW suspension are made out of the same material as the stock 415 arm
3. Remove side to side slop on the sway bars brackets
4. Front diff available as a option
dawgmeat is offline   Reply With Quote
Old 02-05-2005, 10:45 AM   #2
closed rear diff
gizmo is offline   Reply With Quote
Old 02-05-2005, 12:26 PM   #3
RCGaryK's Avatar
I'd love to see an easier way to access the diffs/change diff tension. The front belt tensioner helps a little, but the front belt will still have some twist to it. Other than those two nits, I gotta say I love my 415. Just don't screw up the handling, plllllease. Like when they went to the Evo 3 to the Evo 4 they fixed the wrong problem...the front gear was the problem, not the handling IMHO.
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 02-05-2005, 12:38 PM   #4
TryHard's Avatar
deffiently reduced suspension slop... although baring that the only other thing i can think f is bigger hub bearings. Never really used a diff that much, prefer the one-ways, or even a spool.
Regards
Ed
| THard.co.uk | Xray | MuchMore |
Old 02-05-2005, 06:14 PM   #5
PMR
1. Countersunk upper decks.
2. Countersunk shock towers.
3. Two piece bulkheads for easy diff and belt adjustments.
Other that the 3 suggestions, the car ROCKS and is very STABLE.
PMR is offline   Reply With Quote
Old 02-05-2005, 06:41 PM   #6
TRF Drive Hard's Avatar
Send a message via AIM to TRF Drive Hard Send a message via Yahoo to TRF Drive Hard
An optional front diff and battery brace for saddle would be nice...
TRF Drive Hard is offline   Reply With Quote
Old 02-05-2005, 06:56 PM   #7
dawgmeat's Avatar
No more aluminum turnbuckles and ball studs.
Old 02-05-2005, 06:59 PM   #8
change the blue anodize to red
craziracer is offline   Reply With Quote
Old 02-05-2005, 07:34 PM   #9
Green would look awesome too, i have seen green trf shocks
Old 02-05-2005, 08:23 PM   #10
dawgmeat's Avatar
Old 02-05-2005, 08:24 PM   #11
dawgmeat's Avatar
Old 02-05-2005, 08:24 PM   #12
RCGaryK's Avatar
that's fugly....how about gold?
HorizonHobby.Com
Old 02-05-2005, 08:34 PM   #13
dawgmeat's Avatar
Old 02-05-2005, 08:43 PM   #14
dawgmeat's Avatar
Default Bearing size??
Which ones are used for center layshaft?
Old 02-05-2005, 08:55 PM   #15
Default Re: Bearing size??
840 size or 4 x 8's
Traxxas Slash Improvements Bodies by Dana Electric Off-Road 10 07-31-2008 06:29 AM
Dirt track improvements? HVAC25000 Electric Off-Road 13 01-13-2008 04:39 PM
Site Improvements!!! pc9840 R/C Tech Site Forum 18 10-16-2007 07:15 AM
FS: 415MS BringItOn Australia For Sale/Trade 1 07-11-2006 02:20 AM
Thunder Tiger Performance Improvements RicoDesigns Nitro On-Road 1 06-16-2004 08:47 AM
