-   -   Help Needed 1:10 Bolink problems (https://www.rctech.net/forum/electric-road/623365-help-needed-1-10-bolink-problems.html)
HotRodEnt 04-28-2012 11:41 AM
Hey Guys
I have been fighting a battle and loosing, until now:batman:
I am running 8 bolink eliminator with the following:
Note: I have 8 cars total
ESC :3 Castlewinder SV2 combo with Motor (4 Pole) it says 100,000 RPM MAX
ESC: 3 dynamite Fuze DYN3754
Receiver: 8 Futaba R203GF
Transmitter: 4 Futaba 3PRKA 2.4ghz
Battery: 6 - 7.4V 25C 5800mAH Lipo
Race Track: 1 Micro reality stock car racing size 24' X 24' X 24'
Problems I am having that I would like to address:
console #1 car # 1
ESC and MOTOR running hot after 10 or 15 min of running on 1 Castle
stops responding after a bit will go back and forth but with no steering after a while
Car going way too fast
Console 2 car 2
car glitching with lack of steering at times
car goes way to fast
Console 3 car 3
Car go way too fast
No steering at all but steering
Steering dual rate when I turn it turns the wheel hard to one side
Console 4 car 4
Dynamite Fuse not responding at all only steering works but car does not go back and forth
and the other cars are only for backup.
1 problem I notice after going over manuals again is I did not calibrate transmitter with esc, I tried to follow the instructions, but no go.
Not sure how to go forward.
All parts a brand new and have only been installed and ran once thats when I discovered all of these problem.
Your help will greatly be appreciated
I am located in Kissimmee, Florida, if anyone is near and can assist me that would be great
Open to all ideas
Fuze Manual
.dynamiterc.com/ProdInfo/Files/DYN3740-Manual.pdf
Transmitter and Receiver Manual
//manuals.hobbico.com/fut/3prka-2_4ghz-manual.pdf
This is my current settings for Castle ESC
.castlecreations.com/support/documents/speed_and_gearing_chart.pdf
Castle manual
.castlecreations.com/support/documents/drivers_ed_guide.pdf
Pictures are here:
ps://plus.google.com/photos/108109637442162725515/albums/5736505701066308865?authkey=CPqAno6DtsCb1AE
Thanks so much in advance
Hot Rod
ground-round 04-29-2012 05:28 AM
Could be a million different things. Since you're in central Florida, go to Superior Hobbies and let them sort it out. superiorhobbies.com
competionpark 04-29-2012 05:45 AM
That is WWWAAAAAYYYY too much power for those cars. That is your biggest problem. The motors are probably getting hot because they are geared too low because you are trying to slow them down. A 4600kv motor in a direct drive car running 7.4v through is too much. You should look at getting a motor with about 1/3-1/2 of the KV rating.
