Old 09-23-2001, 04:58 AM   #1
Send a message via ICQ to Tsubasa Sakai
Default M8 and KO RX
Anyone tried to use Sanwa M8 with KO FM receiver??
Tsubasa Sakai is offline   Reply With Quote
Old 09-23-2001, 05:31 AM   #2
Usagi's Avatar
no? why would I? Not trying to a smart butt. But is it possible>
Usagi is offline   Reply With Quote
Old 09-23-2001, 07:38 AM   #3
Regional Moderator
daniz24's Avatar
I have tried it. I combine my M8 with KO's Receiver in my GT-4W, no problem at all.... till now.
daniz24 is offline   Reply With Quote
Old 09-23-2001, 09:27 AM   #4
Usagi's Avatar
That is intersting.............. I thought it was not possible. Well you learn something new everyday
Old 09-23-2001, 10:36 AM   #5
Regional Moderator
disaster999's Avatar
well..actually you could....in fact, you could use it for anykind of receivers its only the cyrstles that you have to change...
disaster999 is offline   Reply With Quote
Old 09-23-2001, 10:56 AM   #6
Alvin's Avatar
What other brands of receivers are compatible with Futaba's 3PDF (Megatech Racer I think...)? I have 2 cars and it's very annoying to shift receivers between my ta04 and tb01 - 04 has a tub chassis - difficult to remove the receiver...
TIA.
Alvin
Alvin is offline   Reply With Quote
Old 09-23-2001, 10:57 AM   #7
Regional Moderator
like i said...all FM receivers with the right band and frequency works!
Old 09-23-2001, 11:04 AM   #8
Alvin's Avatar
Will futaba crystals fit into a KO receiver? One of the LHS selling the 40Mhz KO receivers around S$100 (if I not mistaken) compared to the Futaba FM receivers around S$150...
Old 09-23-2001, 11:09 AM   #9
Regional Moderator
i believe that all the crystals are the same size and stuff...
about the price, its how the manufacture base the price, its like buying power tools, theres lots of brands that could do the job you need...its whether you want to get one that cheap or expensive!
Old 09-23-2001, 12:45 PM   #10
TRF-Powered's Avatar
As long as your transmitter is on the same frequency as your reciever it will work. That's why you can never be on the same channel as others no matter what brand of transmitter or reciver you are using.
TRF-Powered is offline   Reply With Quote
Old 09-23-2001, 01:32 PM   #11
Regional Moderator
daniz24's Avatar
The M8 Tx + KO Rx only works if you use Sanwa's crystals.
Old 09-23-2001, 09:32 PM   #12
Usagi's Avatar
I only used novak, and the sanwa receivers, I never used cross brand receivers. Call me a purest, but I don`t like using other brands other then what its made for.
Old 09-24-2001, 03:37 AM   #13
Alvin's Avatar
cool I'll try out my futaba crystals in the KO receiver. Thanks.
