Translation needed from Yokomo R12 manual
1 Attachment(s)
Normally I would post this in the R12 thread, but I didn't want to limit it to the 1-2 people on the forum that care about the car.... :lol:
I have resurrected my R12 again and have always been curious what the following included option part changed. The manual won't let me grab the text and run it through a translator. I'm guessing it either moves the pin up or down by .5mm, or moves the pin in or out changing arm length. Thanks in advance, it is greatly appreciated. :nod: Next step was to pull the parts off the car and put both up on the comparator. Mike Slaughter |
Whew, good luck with that, lol. You're right about not being able to select the text. Also, it appears that there's no English version around. The manual looks very nice though if it were readable. Bump.
Originally Posted by masterhit
(Post 10650378)
I have resurrected my R12 again and have always been curious what the following included option part changed. The manual won't let me grab the text and run it through a translator. I'm guessing it either moves the pin up or down by .5mm, or moves the pin in or out changing arm length. Thanks in advance, it is greatly appreciated. :nod: Next step was to pull the parts off the car and put both up on the comparator. Mike Slaughter The translation is: do not use the 0.5mm part. This must be because on the basic setup the 0mm part is used. |
(Post 10650378)
I have resurrected my R12 again and have always been curious what the following included option part changed. The manual won't let me grab the text and run it through a translator. I'm guessing it either moves the pin up or down by .5mm, or moves the pin in or out changing arm length. Thanks in advance, it is greatly appreciated. :nod: Next step was to pull the parts off the car and put both up on the comparator. Mike Slaughter http://www.rc-race-and-drift-japan.com/r12/index.htm ML |
