Old 02-03-2005, 03:40 PM   #1
Default getting 30mph out of a 19t
i have a 19t team orion element and im trying to get more top end out of it, the motor has been dyno tested and has a max rpm of 28,510 right now im running it on my tc3 with a 24/72 gear combo, my tires are 2.5'' i want to bump my 24tooth pinion up to a 26t this would give my a gear ratio of 6.92 and should put my right at around 30mph, is this to much for a 19t?
kh15 is offline   Reply With Quote
Old 02-03-2005, 03:43 PM   #2
I would run an even bigger pinion than a 26. something like 5.90 on a reedy 19t or like 6.50 on an element.
John
John Malin is offline   Reply With Quote
Old 02-03-2005, 03:46 PM   #3
isent 26t the biggest you should go before you go down a tooth on the spur?
Old 02-03-2005, 04:05 PM   #4
howard hudson's Avatar
R/C Tech Charter Subscriber
are sure about that?????
what the heck is r/c car??? ( said in your best redneck voice)
'OL BUZZARD FARMING (lol)
howard hudson is offline   Reply With Quote
Old 02-03-2005, 04:08 PM   #5
Bad Boys Racing's Avatar
Send a message via AIM to Bad Boys Racing
i've never heard that.
How hard is it to get 30MPH out of a stock touring car, let alone a 19 turn!
Bad Boys Racing is offline   Reply With Quote
Old 02-03-2005, 04:40 PM   #6
JimmyMac's Avatar
If you have a problem goin to a bigger pinion on the TC3, you can always buy the Trinity TC3 motor cam. It allows much bigger pinions. But like what was said.... You'd need to gear that motor around 5.30~6.00 pending if you racing on a large track or bashing in a large parking lot.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 02-03-2005, 05:27 PM   #7
if i jump up to that 6.50 area with like a 28t will i be pushing it in the overheating dept.?
and i forget where i heard that think about once you get past a certain pinion size you need to drop the spur down but i cant find a 28t pinion on tower they only go up to 26t for 48pitch
Old 02-03-2005, 05:31 PM   #8
Send a message via AIM to T-Money86mcss
Shouldn't be, run a couple mins of practice and if the motor isnt to hot too touch for a second or two, then its fine.
T-Money86mcss is offline   Reply With Quote
Old 02-03-2005, 07:29 PM   #9
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
on a average sized 1/10 electric track stock motors will reach about 30mph. A guy at my local track had a radar gun out, the fastest stock motor down the straight was doing 51km/h.
What have other people gotten stock motors up to geared for a 5min race?
dontfeelcold is offline   Reply With Quote
Old 02-03-2005, 08:36 PM   #10
ChadCapece's Avatar
Radar guns will be inaccurate since there is nothing to bounce the waves off of. The lexan does a poor job, and the car is very small. Our track has tried it several times, all with failure.
ChadCapece is offline   Reply With Quote
Old 02-03-2005, 08:36 PM   #11
Charlie O's Avatar
Just keep gearing it up till it starts getting to hot 180+ or discoloration on the comm, and doesn't accelerate hard anymore, make sure your drive train is free! by the way we usually run 29 or 30/72 on a tc3 or 4 with a 19T.
Charlie O is offline   Reply With Quote
Old 02-04-2005, 05:59 AM   #12
On some of our tracks we run 60/31
Speeds go above 40MPH. (Measured on an AMB speed trap)
With the Element V2 even up to 60/35 due to the lack of RPM.
vassago is offline   Reply With Quote
Old 02-04-2005, 07:39 AM   #13
sonneteer's Avatar
We normally run 4.9 to 5.15 over here with the element...
30mph is easy even with 27T so its really up to track size... if you are racing on track top speed should not be your priority thou...
sonneteer is offline   Reply With Quote
Old 02-04-2005, 11:12 AM   #14
GMartinez's Avatar
Trader Rating: 85 (100%+)
If you decide to go that way & want to prevent heating issues go with a medium brush & purple all around or red to hit that speed
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
