Old 02-03-2005, 06:29 AM   #1
polesitter61's Avatar
Default Novak GT7 Braking profiles?
Can someone tell me what the on track difference between the two braking profiles are? (Drag brake versus the constant force braking) And how it will affect the car while racing? I'm running a xxx-s g+ with a 27 trinity monster stock, ProMatch GP3300's, 24/90 gear (6.86 overall) GT7 esc, novak syn. reciever, and hitech 925 servo.
polesitter61 is offline   Reply With Quote
Old 02-03-2005, 12:33 PM   #2
Anyone?
Old 02-03-2005, 01:09 PM   #3
The Evicerator
Drag brakes will make your car slow down faster when your throttle is at neutral (In dead band). Generally speaking stock motors have more natural drag brake in them than modified motors due to the use of bushings instead of bearings.
I would not recommend enabling drag brakes when using a stock motor as it could make the car feel somewhat hard to drive when off throttle: It might result in abrupt loss of rear traction.
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 02-03-2005, 02:45 PM   #4
That's kinda what I thought, when I raced this past weekend for the first time the car was handling pretty good other than it would slide out the rear just as I would turn in to the corner, not on the brakes at all. I drive a Super Late Model regular race car and that's the way they act when you have too much rear brake. Is there any way to get the "drag brake" out of a stock motor. Because I don't have them turned on in the esc and it still seems that there is too much?
Old 02-03-2005, 02:48 PM   #5
The Evicerator
Make sure that your bushings are oiled before every run and if that is not enough you can try turning up your throttle trim on your radio a few clicks.
Steve Weiss
Old 02-03-2005, 02:55 PM   #6
I have the trim turned up all the way, anymore and it starts to make noise from the esc (trying to move foward) I'll make sure the bushings are oiled every run too. Is it worth pulling the motor apart and polishing the bushings even though the motor has been run about 8 times. It is a Trinity moster stock pro, so it's supposed to be broke in when you get it, brush hoods done, ect.
Old 02-03-2005, 02:58 PM   #7
kartermdb's Avatar
Trader Rating: 15 (100%+)
the motor will always be faster if you do it yourself, regardless if you bought the pro version or not, i have a pro version and when i aligned the brush hoods, i picked up about 1500 rpm on the dyno and got more torque too
Mark Burt
Thanks to:
TRINITY - Revtech - Awesomatix USA - Side Piece Racing - Roche RC USA - Darkside Motorsports - Genesis R/C Raceway
kartermdb is offline   Reply With Quote
Old 02-03-2005, 03:03 PM   #8
I assume I will need to break in the motor if they do need adjusting, so that the brushes can wear in right?
Old 02-03-2005, 03:17 PM   #9
kartermdb's Avatar
yes, i break them in for about 3 min at 2 volts on my chargers
Mark Burt
Thanks to:
Old 02-03-2005, 03:20 PM   #10
Trader Rating: 18 (100%+)
Send a message via AIM to Roberto Falcon
Mark your using the aps charger right?
Roberto Falcon is offline   Reply With Quote
Old 02-03-2005, 03:22 PM   #11
kartermdb's Avatar
yes i have that and my pulsar
Mark Burt
Thanks to:
Old 02-03-2005, 03:24 PM   #12
which do you like better? , i also have a pulsar
Old 02-03-2005, 03:26 PM   #13
Evicerator
Whats the best brake setting racing 19t on the gtx?
Old 02-03-2005, 03:26 PM   #14
kartermdb's Avatar
both are pretty much the same, just the aps tells you rpm and gives you a pulse mode for the break in and it also cuts off charging if you use the temp probe on ur batts i like the aps charger, its well worth the money
Mark Burt
Thanks to:
RCSignup.com - FREE Race Registration - FREE Track Profiles - FREE Racer Profiles superpb Web Links 3 01-16-2008 02:15 PM
