Old 02-02-2005, 01:35 PM   #1
Suspended
Default Foam Tires On The Trf 415
CAN I USE FOAM TIRES ON THE TAMIYA TRF415?CHOCO
SERPENTFREAK69 is offline   Reply With Quote
Old 02-02-2005, 02:23 PM   #2
koabich's Avatar
Send a message via Yahoo to koabich
Ummm....Yes. There are many pages on this in the 415 thread. Do a search.
koabich is offline   Reply With Quote
Old 02-02-2005, 02:43 PM   #3
Suspended
I DID NOT SEE ANYTHING ON THAT...GOT ANY HELP?
Old 02-02-2005, 04:31 PM   #4
I ran into the same problem. The answer is no, the standard 28mm foams that everybody uses does not fit on the front of the 415ms. They hit the steering knuckle before they even come close to tightening up. You have to either cut the foam down to 25mm or switch to HPI Pro 4 steering knuckles and old style tamiya axles which are longer. You can also convert the front end from metric to standard by using Losi steering knuckles, bearings, and Associated nitro TC3 axles with the Tamiya bone. You also have to use a losi or Associated wheel hex with that conversion. You would think that with as expensive a car as the 415ms they would have at least made it so foams fit on it. Around here, nobody runs rubber tires on carpet.
Hope this helps.
HotrodGT*** is offline   Reply With Quote
Old 02-02-2005, 04:56 PM   #5
koabich's Avatar
28MM foams DO fit on the 415...and they can be made to fit with no problem at all.. Actually, I run Jaco tires and they measure closer to 29mm than they do to 28mm.
This is what to do:
-Remove some material from the rear sway bar mount: where it is attached to the rear A-Arm. This will give you the necessary clearance.
-Depending on which hole on the front A-Arm you mount the shock too, you may need to do some work. If you use the inside hole, you will have no problem. If you use the outside hole you will need to remove some material from the bottom of the shock ball cup.
-you will also need to use 1.5mm worth of spacers (Tamiya makes these...not sure on the part number) on each axle to push the wheel out a little. You should do this regardless because this will push the car closer to the 190mm limit and allow for better handleing (yes yyour car will be race legal...depending on which suspension mounts you use).
-Since foam wheels are smller in diameter than their rubber counterparts, you will have to shave the top off of the ball cup that attaches to the top of the castor block.
Between using the spacers and removing some material you will have no problems running foam tires.
Old 02-03-2005, 12:23 AM   #6
Kaobich- Are you running the old 415 with the old suspension, or the new 415MS with the lightweight suspension? On the 415MS with the lightweight suspension there is no way 29mm foams will fit on the front. I put 2mm of spacers on the wheel hex's, and the wheels still didn't even come close to clearing the knuckle where the turnbuckles hook on. I think you might be using the old suspension because on the new suspension there are no interference problems on the rear. The rear sway bar doesn't even come close to the wheel. The two cars have all together different suspension and bulkheads.
Old 02-03-2005, 02:59 AM   #7
Jack2's Avatar
Arrow
cut em down to 26mm the least amount of rotational mass with the right amount of stiction( GRIP)
Schumacher Mi4CX
Mugen MTX & MRX
"He who dies with the most toys wins" - Phil Harris
Jack2 is offline   Reply With Quote
Old 02-03-2005, 07:30 AM   #8
Suspended
VERY INTERESTING...I AM GETTING THE REGULAR 415 SO MAYBE THE FOAMS WILL FIT...I WILLTRY AND SEE...THANKS CHOCO
Old 02-03-2005, 07:38 AM   #9
So are you going to actually bring it out and run with us on wed. nights ??
stumper is offline   Reply With Quote
Old 02-03-2005, 08:13 AM   #10
koabich's Avatar
Yes, I am running the stock 415. That's the car the question was asked for.
Yes, if you do what I suggested, you will have no trouble running foams.
Others have been mentioning that they cannot fit foams on a 415MS and I am not suprized, as that car is designed to be run on asphalt with rubber tires. That is not a foam tire car!!
Hope this helps
Old 02-03-2005, 03:46 PM   #11
415 MS use new reversable arm which WOULD NOT work with 28mm foams.
The old style Arms will work with foams.
rcpinky is offline   Reply With Quote
Old 02-03-2005, 03:51 PM   #12
Suspended
actually yes,i will.....i want to take a little break and run electric but this is my first electric so i may need help out there....choco
Old 02-03-2005, 03:52 PM   #13
Suspended
Hope this helps
thanks a bunch!choco
foam fk05 chasis and foam tires. Branden Moody R/C Items: For Sale/Trade 34 10-09-2007 12:20 AM
What type of foam material are foam tires made from? pirate Electric On-Road 2 04-20-2007 09:40 PM
Foam Tires, Parma, TRC, JACO, Tire truer, Rubbers tires and much much more! Team Speedy R/C Items: For Sale/Trade 43 12-15-2006 10:38 AM
Foam Tires Jye Rookie Zone 1 04-17-2005 05:47 AM
Jaco Foam Tires & Fast Tires Foam, Brand new. MugenMTX3Kid R/C Items: For Sale/Trade 11 01-03-2004 01:53 PM
