Old 02-01-2005, 07:11 AM   #1
Default HPI Pro4 gearing
Hi guys,
I am getting the HPI Pro4 kit, I will be racing 17T Spec class, but the manual syas nothing about gearing for 17Turn motor.
Does anyone here have idead about the gearing ?
plz comment
Snikkari is offline   Reply With Quote
Old 02-03-2005, 12:54 PM   #2
Trinity2's Avatar
I also driven 17t class. Gearing...it always depend on what is the size of the track? Is it carpet or asphalt? Tell more if you want some more info
Trinity2 is offline   Reply With Quote
Old 02-03-2005, 02:39 PM   #3
scoobydo's Avatar
This is actually a great thread to start!
Lets all post some of our gearing for certain track conditions.
scoobydo is offline   Reply With Quote
Old 02-03-2005, 03:21 PM   #4
Hi Trinity2, nice to get some feedback.
I am running on a rather tight carpet track.
Handwound motor, 17x1 and 17x2.
Ill be using LRP Quantum Pro Sport w/4700 power cap and GP 3300 matched cells.
I was thinking of somewhere between 35 and 37 teeth pinion, plz tell me what you are using.
Old 02-04-2005, 10:03 AM   #5
Trinity2's Avatar
Post
Hey there Snikkari.
C`moon scoobydoo man...
At first i recommend you to try gears like: spur 98 and pinjon 35 = 6.83
That is what i liked to use our carpet track what is also technical and tight.
Old 02-04-2005, 11:08 AM   #6
GMartinez's Avatar
Trader Rating: 85 (100%+)
35 and up for large track tracks using 58mm trued tires
If your not afraid of cutting the comm alot you can also go up to 37-38
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 02-04-2005, 01:39 PM   #7
Trinity2's Avatar
Post
Nah. I mean 63mm rubbertires with that gearing
Old 02-04-2005, 01:49 PM   #8
ddesros2's Avatar
When considering gearing always ask "What's your rollout?", by using rollout numbers you can tune for different size tires, different cars, etc..
Here's how to calculate it:
MMPR (MilliMeters Per Revolution, It's how far the car will travel in mm when the motor makes one revolution)
W= Wheel diameter in mm
S= Spur gear teeth (ex: 96T spur)
P= Pinion teeth (ex: 25T pinion)
For cars with internal drive ratios (Like a TC3 or a Pro4, it has an internal drive ratio of 2.5:1) Check your user manual for the drive ratio and add it to the above equation like so:
DR=Drive ratio (Ex: DR=2.5 for a TC3)
MMPR= (1/DR)*(P/S)*(3.1416*W)
Example: I'm running a 19T spec motor in my TC3, what pinion do I use. Guys at the track say that 25 MMPR is a good start.
I measue, W=65mm (full size TC tire), My spur is 100T
P=(MMPR*DR*S)/(3.1416*W)
P=(25*2.5*100)/(3.1416*65)
P=30.6
Round it off to 30T or 31T
Select the 30T or the 31T and try it out.
Ask people around at your track what rollout they use and you can find out your gearing with the above equations.
For a 17T motor on a fast flowing track I would use 30 MMPR to start, for a tighter track try 24 MMPR. Go up or down depending on on how you drive, the temp of the motor, etc..
Hope this helps.
ddesros2 is offline   Reply With Quote
Old 02-05-2005, 02:03 PM   #9
scoobydo's Avatar
Originally posted by ddesros2
When considering gearing always ask .......
That was great. Totally explains how to tackle the question head on. Great post! Thanks ddesros2.
Old 02-05-2005, 03:08 PM   #10
Pro4's Avatar
With 48P gears...
72 spur
anything from 22-30 depending on your track/size etc.
Pro4 is offline   Reply With Quote
Old 02-05-2005, 09:58 PM   #11
scoobydo's Avatar
So basically when you say the motor makes 1 revolution,
you are in essence saying the "pinion gear" making 1 revolution since they are in direct connection to each other right?
Old 02-06-2005, 01:29 AM   #12
Pro4's Avatar
right
Old 02-06-2005, 05:50 AM   #13
fire929's Avatar
Arrow
Hey the por4 has an internal drive ratio of 2.4374:1 for any trying to get rollout.
fire929 is offline   Reply With Quote
Old 02-06-2005, 02:30 PM   #14
scoobydo's Avatar
I been surfing around and nobody is including the internal drive ratio for shaft cars? They are just multiplying pinion/spur and tire diameter*Pie and getting numbers like 71.xxx and such.
Is this for pan cars with 1:1 ratios and belt cars without bevel gears?
Old 02-06-2005, 10:03 PM   #15
Mal
Registered User
I don't get it ... why ask a bunch of people who have never driven or seen your track advice about how to gear?
The best way to find out, is ask the fast guys at your track and then adjust the gearing 3-4 teeth up and down. Gear based on laptime ....
Mal is offline   Reply With Quote
HPI Pro4 f/t or f/s raptor 700 R/C Items: For Sale/Trade 52 01-28-2011 05:41 AM
HPI Pro4, HPI Pro3 and another HPI Pro4 Ty R/C Items: For Sale/Trade 9 04-05-2008 09:54 PM
BMI Pro4 + HPI Pro4 Plus tons of spare Parts Sluggo R/C Items: For Sale/Trade 13 11-01-2005 04:37 PM
WTB: BMI Pro4 Chassis or HPI Pro4 3.0mm Chassis/Upperdeck cpatel529 R/C Items: Wanted to Buy 0 07-21-2005 02:11 PM
wtb: r40 and pro4 owens R/C Items: Wanted to Buy 6 06-28-2005 03:44 PM
