Charging Help!!
Old 01-31-2005, 08:17 PM
RCNitroDude999's Avatar
Trader Rating: 26 (100%+)
Default Charging Help!!
I just got in my first two matched/zapped 6 cell 3300 packs. I tried charging one with a Super Brain 969 charger...the first attempt it peaks at about 300mah. So I discharge and try again. 2nd attempt is about 800mah. I repeat the process again...3rd attempt is 1100mah. Is it supposed to be like this? I am charging at 4.5 amps with a peak cutoff of 30millivolts.
RCNitroDude999 is offline
Old 01-31-2005, 10:10 PM
Default Re: Charging Help!!
Sounds like you just have to cycle it a few times. NiCds take a bit to break in, and they keep getting better for a long time. There was a guy using NiCds in his Tx with a similar problem and every time he recharged em they lasted longer. I guess that's just it. Try putting the battery on a fan or cooler (maybe in the fridge ) while you're charging it. If the pack gets hot it peaks earlier. If it doesn't come close after a few more cycles though I'd take it back and ask for a replacement.
Liko is offline
Old 01-31-2005, 10:23 PM
well one thing, the packs are NIMH and they are not even getting hot when the charger has determined a peak...
Old 01-31-2005, 10:42 PM
Oh. Ummm.... yeah. Just ignore my last post.
Liko is offline
Old 01-31-2005, 10:48 PM
no ideas on what the problem could be?
Old 02-02-2005, 05:20 AM
Jack2's Avatar
HHMMMM. Very strange.
I would ask someone else to charge your packs on a different charger first. I Have never experienced this
If all else fails, Buy- Peak powerflo world spec packs 1.185v+
Jack2 is offline
