Team Titan ARC R10 190mm EP Touring Car
#1187
What size is the stock spur again? If a am correct it's for mod basically which means you would only want to use a 19-22 size pinion. Most stock class guys are using a 88-96 64 pitch spur. Them you would be able to get a pinion range in the high 50's depending on your spur choices from that point.
#1189
The Kit spur is 48dp and my car came with an 82 spur.
Kimbrough spur gears fit
I was running 27/81 at the weekend which is 6:1.
If you are running 17.5 blinky then you will need a lot smaller spur gear (around 66 for 48dp).
#1192
Isn't the stock spur an 84T 48DP?
#1197
good meeting you too.
#1199
So when is the new r10 2014 or 2015 coming? I am patiently waiting for it...
#1200
