Old 04-12-2012, 01:57 AM   #1
Default can someone help with my esc
on i have a tekin g10 esc with a maxtec aftershock motor on my losi xxxs and a and about 3 or 4 days ago it ran fine no problems and today i charged the battery and hooked it up and my esc wont come on is it burn up?
and if it is how can it be burn up without playing with it?
cloudstrife is offline   Reply With Quote
Old 04-12-2012, 02:16 AM   #2
dfiantii's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to dfiantii Send a message via Yahoo to dfiantii
Is it possible that it just died when you plugged it back in. Could you have switched the positive and negative lines even for a moment? If you cannot get it fixed I do have a Tekin G11 I could sell you...
TT-01/Hitec MG/SP LPF V1.1/Trinity 7.5
Losi Type-R/JR Z8800S/SP GT 2.0
Exotek F1R/Savox 1251/Tekin RS
TLR 22 2.0
"ELECTRIFIED TO THE HILT"
dfiantii is offline   Reply With Quote
Old 04-12-2012, 08:27 AM   #3
MrUnlimited's Avatar
Bad connectors, hanging brushes?
U5 Formulaboat 1/8 hydroplane - MHZ138 AQUAMANIA - Axial Exo Terra - Tamiya Avante - LC Racing EMB1 - Atomic AMZ 4WD Touring car
MrUnlimited is offline   Reply With Quote
Old 04-12-2012, 08:42 AM   #4
Does the steering servo works or it's all dead?
Fastfreddy74 is offline   Reply With Quote
Old 04-12-2012, 04:33 PM   #5
the survo dose not work when its pluged into the esc and the motor works when i hook it to a battery the esc wont come on is it dead?
Old 04-12-2012, 04:36 PM   #6
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
If it's not coming on when powered up it's time to check a few things. What battery are you hooking it up to? What type of connectors?
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 04-12-2012, 04:53 PM   #7
Matt Howard's Avatar
didn't the G10 have a "solder fuse"? have you checked that?
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 04-15-2012, 12:15 PM   #8
ok o put new wires on the tekin g-10 and it lights up and works with my survo but when i hook up a motor it just keeps running and makes the esc hot do i have the wires on the motor backwerds or have the moter mounted in the wrong place on the power wire it seems like motor is hooked straight to the battery
Old 04-15-2012, 01:35 PM   #9
Trader Rating: 24 (100%+)
Do you have the manual ? If not ..here ya go.
http://www.teamtekin.com/manuals/g10manu.pdf
I ran all the Tekins from G9 to G12. They're usually bulletproof. Still have a couple somewhere. Good Luck
Evoracer is offline   Reply With Quote
Can I get some help with a SC10 purchace? wrathfull Rookie Zone 22 09-29-2011 08:43 AM
Factory Team B4 Help With Gearing Please ! unseenmagik Electric Off-Road 6 05-07-2010 10:44 AM
