Old 04-11-2012, 07:50 PM   #1
rc10god's Avatar
Default brushless combo problem help!
i just installed a brushless 25.5t ballistic in my tc4. i did the one touch setup and tried running the motor,it doesnt fully spin and sounds like its binding up.I spun the wheels and nothing is caught and the mesh is good. it also runs in reverse and i programmed the edge esc manually to run the other way. whats goin on? it just stutters and makes noise!!!
rc10god is offline   Reply With Quote
Old 04-11-2012, 07:59 PM   #2
hairy's Avatar
Make sure that your sensor wire in fully seated.
hairy is offline   Reply With Quote
Old 04-11-2012, 08:35 PM   #3
rc10god's Avatar
na not it. i push the throttle forward and reverse/brake and either way it goes in reverse. at the same time it snds like its grinding but not moving, retarteddd......
Old 04-11-2012, 09:59 PM   #4
slim jim's Avatar
this just happened to me too,
turns out the magnet spun on the the shaft. time for a new tekin.
Alpha R/C Raceway<<<Intro Vid
OFFROAD* Team Durango DESC40rv2-DESC410r-FUTABA 3PK-AKA-JCONCEPTS
Alpha R/C Raceway
Dammit, I swallowed my gum.
slim jim is offline   Reply With Quote
Old 04-11-2012, 10:07 PM   #5
rc10god's Avatar
dam man i just got this today, is there a way to fix it
Old 04-11-2012, 11:31 PM   #6
are you sure all the wires are well soldered and are on the correct place on the motor/speedo ???
You may laugh but i have seen experienced races make this mistake !!!
Have you tried a new sensor cable ??
sidecarphil1 is offline   Reply With Quote
Old 04-12-2012, 06:29 AM   #7
slim jim's Avatar
with the amt. of torque the rotor sees i doubt it.
Alpha R/C Raceway
Old 04-12-2012, 08:04 AM   #8
rc10god's Avatar
yea i checked all conjnections,ill try a new sensor wire. it just vibrates and clicks very fast lol. cgcgchghhchgchgchchgc like that lol.
Old 04-12-2012, 08:18 AM   #9
mkiiina's Avatar
Trader Rating: 69 (100%+)
Try swapping 2 of the wires. I had this happen with my tekin RS Pro and x12, after swapping 2 wires everything was perfect.
mkiiina is offline   Reply With Quote
Old 04-12-2012, 08:20 AM   #10
MrUnlimited's Avatar
What connectors are you using? Make sure they can draw enough current.
U5 Formulaboat 1/8 hydroplane - MHZ138 AQUAMANIA - Axial Exo Terra - Tamiya Avante - LC Racing EMB1 - Atomic AMZ 4WD Touring car
MrUnlimited is offline   Reply With Quote
Old 04-13-2012, 06:07 AM   #11
slim jim's Avatar
going to try some red loktite. ill let you know the result.
Alpha R/C Raceway
Brushless Combo for Drifting stylomilo Singapore R/C Racers 189 03-12-2009 06:55 AM
Most popular(best) brushless combo for B44 absoluttorque Electric Off-Road 105 12-23-2007 10:17 PM
