Old 01-31-2005, 02:13 PM   #16
pookat's Avatar
Beat me to it, long drive from work n all.
pookat is offline   Reply With Quote
Old 01-31-2005, 02:32 PM   #17
ohh.. belt drive shaft!
MartynD is offline   Reply With Quote
Old 01-31-2005, 02:40 PM   #18
Send a message via AIM to dasupacat
It's too bad the HPI PRO3 & KYOSHO KX-1 didn't take off. It woulda been nice if they made a 2nd version of each with updates instead of jumping on the shaft wagon. It was good to see a both mfr. take a chance though.
dasupacat is offline   Reply With Quote
Old 01-31-2005, 02:47 PM   #19
ChrisP's Avatar
Why not have the outdrives different lengths front and rear....
so that the ring gear would be on the opposite side of the shaft...
one outdrive like this
the other like this
Batteries not down the centerline....but closer...
The hard part is the motor placement and achieving balance...you have to be ale to get power to the drive shaft...not just betweenthe diffs....and still somehow try and achieve a relatively even L/R weight distribution...
ChrisP is offline   Reply With Quote
Old 01-31-2005, 02:50 PM   #20
mushu's Avatar
I must have missed something on this, but why don't people think it would be easy to do a split layout shaft drive car? Take a look at this image. Pardon the dimensions they are a little off, but you'll get the idea...
mushu is offline   Reply With Quote
Old 01-31-2005, 03:10 PM   #21
berger's Avatar
R/C Tech Charter Subscriber
Too much weight on the motor side? The cars that do run side by side have the motor moved towards the centre balancing it a bit better.
berger is offline   Reply With Quote
Old 01-31-2005, 03:14 PM   #22
Jack Smash's Avatar
Trader Rating: 29 (100%+)
the other like this
I was actually just thinking about that setup but I am having trouble figuring out the motor placement and steering arrangement in my mind. I might have to break out the old drafting table soon.
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 01-31-2005, 03:20 PM   #23
pookat's Avatar
I wasn't hoping to make anybody design a car, just pointing out it was possible. Does seem like a good idea though doesn't it!
Old 01-31-2005, 03:42 PM   #24
Regional Moderator
Darkseid's Avatar
I actually remember seeing a TC3 re-arranged like that back in the day. It was in a pic of a race meeting, but I can't remember from when.
It was like one of those occasions where one of the magazines showed a weird car they spotted at a big race. You know, like seeing a Losi 2wd buggy with inboard shocks or something. One of those things that just caught people's eye.
TLR 22...Tamiya F104...
Old 01-31-2005, 03:44 PM   #25
sosidge's Avatar
The most recent Durango 4wd offroader ran the shaft down the centre, over the batteries (saddle pack) and motor. It won the European Championships, so it can't be that bad. Sadly, the site www.rc10.de doesn't seem to be accessible at present.
Old 01-31-2005, 03:45 PM   #26
sosidge's Avatar
Here ya go...
Old 01-31-2005, 03:53 PM   #27
ChrisP's Avatar
with a shaft drive you wouldn't be able to run the batteries down the direct center of the chassis and still achieve balance...you'd have to haev them stil slightly off-center away from the motor...this will also help keep the motor from sticking too far out the side and can lend itself to better weight distribution...
Looking at that, along with a wide diff/short arm setup with unequal length diff outdrives and it has potential. One MAJOR drawback that I can see though isthat this design would require each corner f the car to have its own unique outdrive.....
oooohhhh.....unless a common outdrive was used with an offset gear!!..hmmmm...
it'snot just to be ablet o come up with a car that will work, but to come up with one that will work withthe minimum of unique parts so that it can be produced and marketed at a price that will generate order volume while still creating profit...
Many 1:1 cars are produced as fantastic concepts and marvels of engineering but die because there wasn't a sound business case for the production...
Old 01-31-2005, 03:57 PM   #28
ChrisP's Avatar
TheDurango is a different beast altogether...and I STILL don't care for the battery configuration....a saddle with near o clearance between cells.relying on a lexan shiield or something....just seems wrong...I dunno...
apparently it performs..but I don't that that would ever sell in the touring car market...
Remember..the touring car crowd are the same group that complained that the Xray had a higher-than-necessary CG because of the lightweight spurgear and hollow layshaft being elevated...
what do you think they would say about the spur geat and aluminum driveshaft being up in the air??
Old 01-31-2005, 04:02 PM   #29
Default So whats the consensus?
I dont want to get into a shaft vs. belt debate, just want to know if having your batts down the center is superior to other placement...........
Ginsu is offline   Reply With Quote
Old 01-31-2005, 04:13 PM   #30
ChrisP's Avatar
It's all about physics...having the mass centralized as much as possible helps the car to rotate easier...a lower Polar Moment of intertia
An example is a figure skater who begins a spin by inputting energy...arms outstretched they have a relatively slow spin....the frictionof the skate's bladeont he ice should consume energy and slow things down, but instead the skater draws their arms closer to their body and the rate of spin increases. The mass didn't change, there was no additional energy contributed (on the contrary...it is being constantly lost to friction) yet the rate os spin increases greatly because the skater has reduced their polar moment of inertia by moving the mass closer to their center of rotation...
This is a general explanation, as it has been over 10 years since I studied itand I don't feel like diggin up my engineering texts...but the theory is sound....
Touring car designers wantt o centralize the masss as much as possible to allow the car to rotate well..but they also need to keep a low center of ravit for handling..
it's a struggle that they wrestle with...in orde to stay low they may have to spread things out....in order to take less energy to change direction..they need to keep the 'spreading out' to a minimum...that struggle s what keeps the designs changing and evolving
and then of course there's the different pros and cons of different power transmision methods..but that's another topic altogether
Electronic Placement? Associated-08 Electric Off-Road 0 03-04-2008 09:12 PM
ZX5 Electronics placement ThunderRobo Electric Off-Road 12 01-10-2008 07:54 AM
xxx4 battery placement Driver1 Electric Off-Road 7 04-06-2005 09:41 PM
NEW XXX-S/4 Battery Placement Ideas Driver1 Electric Off-Road 2 04-03-2005 05:19 AM
esc and rx placement in micro rs4 SunRunner Electric On-Road 0 09-27-2002 09:37 AM
