Looking for servo connector pins any help? >
Old 01-31-2005, 05:06 AM
WVRACER's Avatar
Default Looking for servo connector pins any help?
! like to cut all my wires to length and I can not find a place to buy the pins that are in the servo connectors.
If any one you know of a place please drop me a link.
Much Thanks
Rob
WVRACER is offline
Old 01-31-2005, 05:09 AM
1fastdude's Avatar
Trader Rating: 15 (100%+)
Default pins
Horizon Hobby, I believe sells these items. I will try and find a part number for you.
1fastdude is offline
Old 01-31-2005, 05:12 AM
Company Representative
Tres's Avatar
Trader Rating: 14 (100%+)
http://www.conec.com/section2/new.di...chart=34&dia=2
Sub d pins
Tres is offline
Old 01-31-2005, 05:32 AM
Mr. Shookie's Avatar
If you have a good Soldering iron and a steady hand I would just open the case and re-solder the right lenth and nothing to buy.
Just my two pennies,
Also I use the extra wire of non re-sized lenths and wrap it around ferrit coils to remove any radio noice.
Hope this helps,
Stephen <><
Mr. Shookie is offline
Old 01-31-2005, 05:51 AM
WVRACER's Avatar
thanks guys i knew i could count on this group.
mr fast dude how do the amish know so much about electronics just kidding that link would be greatly appricated
Tres it helps to know what there called. "servo connector pin" was not working to good for me
Stephen i have been doing that to now i just keep running into problems like my iron hittig a wire and it will be ruined till i can get it fixed or wanting to put the servo in a different application.
thanks for the tip though.
I used to keep all my wires in tie wraps and it looked real messy them i meet a guy named Tony Williams in cleveland one year that showed me the bennifits of a clean wiring system and i have been crazy about keeping a clean wiring system every sence
thanks guys
Rob
WVRACER is offline
Old 01-31-2005, 06:15 AM
1fastdude's Avatar
Default connectors
These are the part numbers for what I found:
"JR" cel1176
"Fut" cel1175
You will need a cel1179 crimping tool also. Hope this helps and don't let the Amish community know I'm using electric!!!!
Old 01-31-2005, 06:29 AM
Tres's Avatar
LOL @ Eli....Shack has a sub crimper also, like $7
Tres is offline
Old 01-31-2005, 07:10 AM
BigDogRacing's Avatar
LOL- I just realized, you DO look amish Eli!!!
Here's a good place to get the servo parts you need: www.servocity.com
BigDogRacing is offline
Old 01-31-2005, 07:51 AM
WVRACER's Avatar
thanks guys much appricated
don't worry Eli thay will never know
WVRACER is offline
