Deans Speed Jig Question >
Old 07-01-2002, 06:05 PM
AMGRacer's Avatar
Default Deans Speed Jig Question
I purchased a speed jig and have been usingit to make very nice 2000 packs. Today I bought some new 3000s and went to build them, no go!! They do not fit into the jig. I ended up filing the edges of the jig away some to allow them to fit.
Has anybody else had this problem, or did I buy the wrong jig for 3000s??
AMGRacer is offline
Old 07-01-2002, 06:20 PM
i have this jig and i think the last ttime i made 3000s with it i didnt have much of a problem, but i think i do remember it being a pretty tight fit though, not enough to have to file anything.
Jarrod Langlois is offline
Old 07-01-2002, 06:26 PM
Balak Racing's Avatar
I've had no prolems with the Panasonic Ultral Metal Hydride cells in my Deans Jig. Worked perfectly.
Bryan
Balak Racing is offline
Old 07-01-2002, 06:30 PM
AMGRacer's Avatar
Hmmm looks like I lucked out. These things WOULD NOT fit in even tight. They are tight now after I filed the thing down.
They are Team Corally Pro Sanyo High Voltage 3000.
OK thanks guys!
AMGRacer is offline
Old 07-01-2002, 06:39 PM
Trader Rating: 82 (100%+)
i think the sanyo nimhs are slightly bigger in diameter than the panasonic smh. the sanyos are also a tight fit when im using the jig, compared to the smh's which fit easily.
marvi is offline
Old 07-01-2002, 06:55 PM
AMGracer, I know what you are talking about, I had to take a dremel to my deans jig in order to build some Sanyo 3000HV packs. I beleive the jig is okay for the SMH's but the HV's a slightly larger. Dean's is aware of this issue an has updated their jig so that the new Sanyo 3000HV's will fit, you just have the older version.
ZER01 is offline
Old 07-01-2002, 07:15 PM
AMGRacer's Avatar
Ahhhhh I thought it could not just be me . Do you know of a new part number or how to tell the new jig?
AMGRacer is offline
Old 07-01-2002, 07:37 PM
RCTech Member #2
TSR6's Avatar
My 3000 cells fit in the old jig, but you have to use some force.
I found out about the update a couple months ago, bummer!
-Troy
TSR6 is offline
Old 07-01-2002, 10:36 PM
That's cool to know. I also had that same problem as some of you guys did with the fit of Sanyo 3000 cells. Have they released an updated version? How would we tell from the old one versus the new one?
Dayten is offline
Old 07-01-2002, 11:02 PM
Okay, the new version states that the new Sanyo 3000HV will fit for this jig. I'm sure their site will tell you this also but their new site is under contruction.
ZER01 is offline
Old 07-02-2002, 01:50 AM
JohnA's Avatar
I just bought a deans jig with "Now updated to fit Sanyo 300's" on the packet.
JohnA is offline
Old 07-02-2002, 02:36 AM
AMGRacer's Avatar
Where did ya get it (what shop?) How much?
AMGRacer is offline
Old 07-02-2002, 05:17 AM
Didn't you get one that has a foam block that you stick on one end of the jig? The Jig should be big enough for any 6 cell batteries and the foam is to snug the pack up.
Sydewynder is offline
Old 07-02-2002, 08:08 AM
JohnA's Avatar
Both the old & new models have the foam in one end, the new version is a bit bigger width ways as the Sanyo 3000's are slightly longer than other cells.
I got it from Dave Guyatt, he has a mobile shop and attends Wynum & Meakin Park race meetings, about $30, I think.
JohnA is offline
