Like Tree1Likes
Xray T1FK05
Old 04-03-2005, 02:54 PM
  #1441
John Fontaine
How did you "modify" it?
dway100 is offline
Old 04-03-2005, 03:02 PM
  #1442
John Fontaine's Avatar
I moved the location of the antenna holding post to between the servo and upper deck standoff.
I removed the CF between the two servo holes (my Futaba S9451 was right in the middle of two holes) so I can secure my servo down without taking realestate away from the electronics.
Milled part of the motor hold down away so it clears kimbrough spur gears. Little things like that, not too major
John Fontaine is offline
Old 04-03-2005, 03:34 PM
  #1443
dway100, looks like John's mods are form following function...I wouldn't blindly do them to your car unless you need it.
tminus3 is offline
Old 04-03-2005, 05:12 PM
  #1444
Default xray
sounds liek the car is very fast, i can't wait till i recieve mine and start building it.
RUKidn is offline
Old 04-03-2005, 05:30 PM
  #1445
kidDynomite's Avatar
John, those are some of the things I did with the servo and motor mount. Guys, this way you don't have to shave every spur, especially durning a meet. Just take a sharpy and mark out the shape of the spur on the motor mount. And then shave off about a mm by grinding it on the side of a grinding wheel on a bench grinder. Comes out clean and you never need to worry about spurs fitting.
kidDynomite is offline
Old 04-03-2005, 07:18 PM
  #1446
Default first race with the fk05
This car is just awesome. I have been racing for 4 years now and I have never had a change in cars improve my times by 1-2 laps. The pro 4 I had never drove this good out of the box with just a few changes to the stock setup
Andy C is offline
Old 04-03-2005, 08:07 PM
  #1447
Cool... I can't wait to try mine. I've been fast, lets see how fast I can be now
Old 04-03-2005, 08:59 PM
  #1448
HarshGuy's Avatar
A better solution using common household materials, locks that battery in with no movement whatsoever:
HarshGuy is offline
Old 04-03-2005, 09:03 PM
  #1449
Oasis's Avatar
Trader Rating: 38 (100%+)
..Thats just so getto..AE,,
Oasis is offline
Old 04-03-2005, 09:05 PM
  #1450
ChrisP's Avatar
What brand of Spur is that Harshguy???
ChrisP is offline
Old 04-03-2005, 09:08 PM
  #1451
Twin-Kyle's Avatar
First...That will cause your chassis to tweak BAD. Take it off and tape your batts in.
Second.. How did you get that spur gear in.Thought those didn't fit?
Twin-Kyle is offline
Old 04-03-2005, 09:20 PM
  #1452
HarshGuy's Avatar
Spur gear fits fine:
I'm checking out the tweak situation now, I didn't even thin about that ...it's kind of a pain to tape then in this car and they were "wiggling around" which I didn't like, my velcro solution was better than tape but they still wiggled around.
...stay tuned!
HarshGuy is offline
Old 04-03-2005, 09:23 PM
  #1453
ChrisP's Avatar
Again...what brand is the spur..the only one I had seen like that was an 8 hole pattern on the inner ring instead of 6...
ChrisP is offline
Old 04-03-2005, 09:27 PM
  #1454
Twin 1 Kevin's Avatar
It looks like a RW gear. Same as the one in my 12 scale.
Twin 1 Kevin is offline
Old 04-03-2005, 09:28 PM
  #1455
ChrisP's Avatar
Which is why I was asking...all of the ones I've seen where an 8 hole pattern on the inner ring....
I'd like to get ahold of some if they have a 6-hole...
ChrisP is offline
