Like Tree1Likes
Xray T1FK05
Old 03-30-2005, 12:10 PM
  #1291
kewdawg's Avatar
Originally posted by cvt01
"but why does it feel so "dry"? "
I recommend to disassemble all the diffs before use. My FK04 came with a dry diff. It is just an assembly mistake of the factory operators - I don't blame them, for me is building two diffs a day is more than enogh and they build what? like hundred a day
Mine weren't dry at all? This is my second "new" Xray and neither had "dry" diffs. The diff just aren't packed with an excessive amount of diff lube. But if, you truely believe they're "dry", feel free to re-build. I don't think it's necessary. Xray's assemblers are usually on-point with partial assembly and packaging the kits. I don't think you have anything to worry about.
kewdawg is offline
Old 03-30-2005, 12:42 PM
  #1292
StewartFan20's Avatar
Default Dry Diffs
Both my diffs were bone dry. In fact, I fried one of my diffs the first day I had it because it was bone dry. Not a drop of lube anywhere.
StewartFan20 is offline
Old 03-30-2005, 12:57 PM
  #1293
kewdawg's Avatar
Default Re: Dry Diffs
Wow!? That's the first time I've heard of that happening.
kewdawg is offline
Old 03-30-2005, 01:02 PM
  #1294
John Fontaine's Avatar
I'll be redoing my difs with Mugen super grease on the thrust bearings. Never blew anything using that stuff...not even nitro thrust bearings in the centax clutch!
John Fontaine is offline
  #1295
I took the second diff apart and saw hits of lube and grease. But not near enough to do the job.
So, I would recommend tearing the diffs down and re-lubing them.
Old 03-30-2005, 01:17 PM
  #1296
Originally posted by John Fontaine
Instead of adjustable shocks, I might build this set with regular holed pistons... hmm
John,
This is Abhi from Horsham...
Build your shocks with the adjustable pistons, I noticed that once the shocks are made, its hard to get to the pistons, without taking the ball cup on the end off.
That was my observation.
tminus3 is offline
Old 03-30-2005, 01:41 PM
  #1297
I know...i've had the adjustable on my xray that I just sold... Oh, I know all about Xray shocks from driving an xray for the last 3 years...lol
Old 03-30-2005, 01:45 PM
  #1298
kidDynomite's Avatar
That's how Josh did his shocks. Fixed pistons with the correct amount of pack from specified weight oil.
I'm with Kewdawg on the shocks. I hated them, but never gave up on them. Just needed to figure out a good method of re-building them.
Some people get air bubbles in their shocks when using the adjustable pistons and can't figure why. The 30wt Xray oil is relatively thicker than Trinity or AE oil of the same rating. Make sure that after you fill the shock body with oil, you pump and "key in" the piston in each locking groove at the base of the shock body to ensure that they're are no air pockets. Also make sure to pump out the air while adjusting the the piston settings... one hole closed, two holes closed etc. They're are lots of little holes on the adj. pistons for air to get trapped in.
kidDynomite is offline
Old 03-30-2005, 02:14 PM
  #1299
kewdawg's Avatar
Good instructions. That's exactly how I build them. Xray 30wt. should be equivalent to Trinity 60wt..
kewdawg is offline
Old 03-30-2005, 02:38 PM
  #1300
Steve Bahnatka's Avatar
kewdawg ygpm
Steve Bahnatka is offline
Old 03-30-2005, 02:40 PM
  #1301
Midnight's Avatar
Trader Rating: 87 (100%+)
So is that about losi 50 wt?
Midnight is offline
Old 03-30-2005, 03:06 PM
  #1302
ALBERTO's Avatar
Trader Rating: 23 (96%+)
Are you sure about that.... I'm only asking cause that seems like a big differanse in weight. I was always under the assumtion that we all masure oil in the same mannor...... if not i just learned something new
ALBERTO is offline
Old 03-30-2005, 03:14 PM
  #1303
Midnight's Avatar
You have to realize that xray is one of the best engineered vehicle ever made. They seem to take things for instance shock oil, to a whole new level.
Midnight is offline
Old 03-30-2005, 03:17 PM
  #1304
kewdawg's Avatar
Originally posted by Little Bahnatka
kewdawg ygpm
Yeah... well now ygpm.
kewdawg is offline
Old 03-30-2005, 03:18 PM
  #1305
kewdawg's Avatar
Don't know the conversion to Losi oil wt., sorry.
kewdawg is offline
