Like Tree1Likes
Xray T1FK05
Old 03-28-2005, 11:08 AM
  #1156
duckman996's Avatar
Trader Rating: 14 (100%+)
Originally posted by MrRolla
Guys,
I have a problem with the rear suspension, in particular the aluminium nut for the pivot pin (302032). The problem is i have i that is completely round but i dont have a completely round holder (302040) for it there for i cant fit the aluminium nut in the holder...
It is late here and i am tired so please tell me its something stupid i have overlooked or have I been given a wrong part??
Please help a fellow Xray Fan get his kit built
I think that you got the wrong part ... either you get another one or you can drill out the plastic part that it goes into and be on your way (although, it will make it harder to tighten the screw that holds it in place). Personally, I would get the right part for it. Try calling the store you got it from and see if they can help you.
duckman996 is offline
Old 03-28-2005, 11:12 AM
  #1157
duckman996's Avatar
Originally posted by MartynD
My guess... it will go together once you have had some sleep..
For me... I cannot complete my car because of one 5x1 o-ring.. Kit came with 3, instead of 4. Store I bought the kit isn't open again until Tuesday.. and even then.. I hope they have the part...
Martyn,
Try Advanced - they are open today.
Old 03-28-2005, 11:13 AM
  #1158
duckman996's Avatar
Originally posted by rayhuang
Please excuse me if I am not following this right-but I think with a file or dremel-can you not put the flat on the insert so it will fit? The parts is junk anyways-so if you bugger it up-who cares?
Or you can go this route (which is better then the one that I recommended)
Old 03-28-2005, 11:16 AM
  #1159
Midnight's Avatar
Trader Rating: 87 (100%+)
Does anyone know what my gear ratio would be if Im running a 84 spur, with a 27 or 28 pinion on the FK 05.
Midnight is offline
Old 03-28-2005, 11:28 AM
  #1160
theisgroup's Avatar
it woudl be spur div pinion multiply by 1.7. so
84/27*1.7 or 84/28*1.7
theisgroup is offline
Old 03-28-2005, 11:32 AM
  #1161
brad996's Avatar
do any of you guys have any tricks to stop my car from glitching I am running a gtx and a xxtra novak reciever and a new hitec
hsc-5996tg servo this is my first carbon fiber car
any help
brad996 is offline
Old 03-28-2005, 11:36 AM
  #1162
rcfiend's Avatar
Trader Rating: 41 (100%+)
Hey guys i'm ordering a bunch or replacement parts for the fk05 and I can't recall if the diff pulley is a 34. Am I right.
rcfiend is offline
  #1163
rctoyguy's Avatar
Trader Rating: 21 (100%+)
Alright - going to really show some ignorance here, but that's how you learn, right?
Isn't the FK05 Graphite? And graphite & Carbon Fiber are not the same thing, right?
About the glitching, Is this regardless of the motor you are running? I had a major glitching issue this past weekend, but it was only with one motor - others were fine. I haven't looked at that motor yet to see what's going on, but that is something you can check. If it is will all motors, do you have a schottky diode on them? That can help with glitching - also be sure the antenna on the RX isn't rubbing anything on the chassis.
rctoyguy is offline
Old 03-28-2005, 11:38 AM
  #1164
HarshGuy's Avatar
goto www.gearchart.com ...pick "Gearchart Creator" ...pick the "Xray T1 FK 05" from the drop down, input 84 for spur, 27 for pinion ...click the "Gear Ratio" button.
HarshGuy is offline
Old 03-28-2005, 11:39 AM
  #1165
Hyperform Racing's Avatar
anybody know where I can get a front sway bar kit? Everyone seems to be out of stock...
Hyperform Racing is offline
Old 03-28-2005, 11:40 AM
  #1166
Midnight's Avatar
Thanks. Just wanted to make sure I was on the right page when I get my car(any day now) How would you do this if your running 64 pitch?
thanks in advance!
Midnight is offline
Old 03-28-2005, 11:42 AM
  #1167
theisgroup's Avatar
the pitch of the gear does not change the forumal for final drive ratio. the pitch only refers to the number of teeth per inch.
Old 03-28-2005, 11:52 AM
  #1168
ALBERTO's Avatar
Trader Rating: 23 (96%+)
front sway bar thercshack.com
ALBERTO is offline
Old 03-28-2005, 02:23 PM
  #1169
Midnight's Avatar
any help
Can you post a pic of how your electronics are layed out?
Midnight is offline
Old 03-28-2005, 02:34 PM
  #1170
dr_hfuhuhurr's Avatar
Trader Rating: 93 (100%+)
Take the hitec servo out and return it before it gets used...They aren't that great...
dr_hfuhuhurr is offline
