Like Tree1Likes
Xray T1FK05
Old 03-24-2005, 04:13 PM
  #946
kewdawg's Avatar
Originally posted by John Tag
Its about time you got toys like us
Yo, tag! Where ya' been, buddy?! We miss at D.C. Ultra or should I say, Horsham R/C. What "toys" would you be referring to? I only have finely-tuned racing machines at my house.
kewdawg is offline
Old 03-24-2005, 04:14 PM
  #947
John Tag's Avatar
Trader Rating: 42 (100%+)
Ill be at Horsham saturday, I have a package to deliver to Jim See ya there.
John Tag is offline
Old 03-24-2005, 04:17 PM
  #948
ALBERTO's Avatar
Trader Rating: 23 (96%+)
i just finished building my fk05 and i gotta say this sucker is perfectly balanced even wit the batteries on one side. The only thing i dont really like is the 48 pitch spur gear. What 64 pitch spur are you guys using. I know the largest is 116
ALBERTO is offline
  #949
komkit's Avatar
Default Part # 307454 Pivot Ball
In the bag # 05 - Front Suspension
Am I suppose to get these??? It doesn't look right????
These were only two in the bag.
komkit is offline
Old 03-24-2005, 04:26 PM
  #950
kewdawg's Avatar
Sounds good. I'll be bringing up the rear, as usual (I'll shoot down after work so I just make the 1st heat - you know me. Hey, wait a minute! Would that package contain some high voltage items?
kewdawg is offline
Old 03-24-2005, 04:28 PM
  #951
Default Re: Part # 307454 Pivot Ball
yes you were suppose to get them.....on the front shock tower you are suppose to slide a 3 x 10 screw through the shock tower then screw a M3 nut onto the screw then screw that ball on the same screw against the M3 nuts..
hope that helps....
HEWITT is offline
Old 03-24-2005, 04:32 PM
  #952
kewdawg's Avatar
I think that's the "1 million dollar question". I'm dying for the answer to that one. The only thing is... people are just getting their cars and assembling them. maybe we'll have a good gearing by next weekend, hopefully. Either way, I'll have some fun trying to figure it out.
kewdawg is offline
Old 03-24-2005, 04:37 PM
  #953
Steve Bahnatka's Avatar
quinn, did u get one yet??? i got mine. i gotta buy some new spurs.-lil' B
Steve Bahnatka is offline
Old 03-24-2005, 04:39 PM
  #954
komkit's Avatar
Default Re: Re: Part # 307454 Pivot Ball
hope that helps....
I have already installed two on the front shock tower. 303240 Ball universal 5.8mm HEX
But these two (in the photos)... I think it suppose to be installed on the caster block for the camber linkages. The part number for these two I think it was 307454 Pivot Ball 5.0 double bevel shoulders.
komkit is offline
Old 03-24-2005, 04:50 PM
  #955
scoobydo's Avatar
Just got mine today from SpeetechRc!
Cant wait to build. Ditto on the spur question as I will be using 64 pitch.
Any of you have info on the Belt Tensioner option?
This is my first belt as I have been only into shaft.
What are the advantages of using this? What does it do?
scoobydo is offline
Old 03-24-2005, 04:53 PM
  #956
it mostly makes sure the belts wont skip and to make it maybe smoother mostly....
HEWITT is offline
Old 03-24-2005, 04:54 PM
  #957
GMartinez's Avatar
Trader Rating: 88 (100%+)
Speaking with Mr Burch from X Ray @ the Nats I think you will be able to use the 100 tooth spur I think it's the biggest that will fit.
Anyone has a suggestion on what oil to use outdoors
GMartinez is offline
Old 03-24-2005, 04:56 PM
  #958
xray 30 wt works good.....i use ae 50wt all around...i feel like that works for me the best but also people do use ae 40 wt all around also...
HEWITT is offline
Old 03-24-2005, 04:57 PM
  #959
tboned_2002's Avatar
112 matches up pretty well with 84 tooth spur in 48 pitch
116 / 87
www.teamxray.com has outdoor setups on the car. Look in the Forum.
tboned_2002 is offline
Old 03-24-2005, 04:58 PM
  #960
scoobydo's Avatar
So with 84/16 I get the rollout I am looking for. 22.88mm FDR 8.925
If I wanted to use 64 pitch I would have to use 100/19 to get 22.82 FDR 8.947
Is that right or does one have to use a different equation when formulating 48 pitch as opposed to 64 pitch?
Do you just use the same equation?
scoobydo is offline
