Like Tree1Likes
Xray T1FK05
Old 03-23-2005, 05:34 AM
  #856
StewartFan20's Avatar
Default Ackerman settings
I have looked all over and cannot find anything that tells me what the different ackerman settings do. i.e. what would happen if I rotated the servo saver holder 180* from the stock setting?
StewartFan20 is offline
Old 03-23-2005, 06:04 AM
  #857
Midnight's Avatar
Trader Rating: 87 (100%+)
Hey Devil dog If you look on the Xray website, someone posted this PDF file that breaks it all down. It tells you about camber, ride height, droop and so on. Hope this helps!
MSHAP33 I think Im going to go with the 112 tooth b/c I never plan on running the 3mm chassis. You can go to rcshack.com and they carrry 64 pitch spurs!
For everyone who has their kit already, I will be with you soon.LOL
Midnight is offline
Old 03-23-2005, 06:12 AM
  #858
Midnight can you post the link for the PDF???
thanks
harris is offline
Old 03-23-2005, 06:17 AM
  #859
I think I have seen the document. It basically the manual for the setup station. It is also included in the kit and it has some great information. It talks about everything BUT ackerman.
Old 03-23-2005, 06:20 AM
  #860
Heheheh
So where are we going to find my friend Ackermann....
harris is offline
Old 03-23-2005, 06:34 AM
  #861
Shop Owner
nnick's Avatar
This pdf can be found also here
And you are right it doesn't say anythign about ackerman
Nick
nnick is offline
Old 03-23-2005, 06:42 AM
  #862
Does anyone know why the thrust bearing has two different shim sizes (different internal and external diameter)?
Thanx people.
aantonis is offline
Old 03-23-2005, 06:45 AM
  #863
The ackerman extension gives less 'toe out' in the corner, I think this means less front traction and higher cornering speed. Can be I'm wrong.
cvt01 is offline
Old 03-23-2005, 06:53 AM
  #864
John Doucakis's Avatar
In order to fit Tamiya Shocks you will need the following:
PART Nr. DESCRIPTION
53571 | FLUORINE COATED DAMPER SET (4)
49293 | FLUORINE COATED DAMPER SET (4) - BLUE
49294 | FLUORINE COATED DAMPER SET (4) - RED
53598 | AL. 5 mm Ball Connectors (10) for suspension arm
53642 | AL. 5 mm Ball Connectors (10) for suspension arm - BLUE
53599 | AL. 5 mm Ball Nut (10) for shock towers
53640 | AL. 5 mm Ball Nut (10) for shock towers - BLUE
50596 | Adjuster 5 mm 81/02 plastic for lower end of shock (rear)
50797 | Short Adjuster 5 mm plastic for lower end of shock (8pcs) (front)
50875 | 5 mm ball connector set TAO4
John Doucakis is offline
Old 03-23-2005, 07:08 AM
  #865
Yes, I belive you are correct. I would just like to know what the different servo saver settings do. What is the ackerman setting if the servo saver shaft is toward the rear vs toward the front (stock).
Old 03-23-2005, 07:25 AM
  #866
Midnight's Avatar
Sorry I couldnt be of assistance. Here is that link: http://www.hudy.net/xhudy/showfile.p...252739b1ad8c24 . I cant open it from my work computer. The other day at school was when I found it.
Devil Dog where are you stationed?
Midnight is offline
Old 03-23-2005, 07:29 AM
  #867
Thanks Johnny
thats all I wanted to know 4-5 pages back
aantonis is offline
Old 03-23-2005, 07:53 AM
  #868
I am in the Greater KCMO area.
Old 03-23-2005, 08:07 AM
  #869
Midnight's Avatar
Isnt that by fastlanehobbies.
Midnight is offline
Old 03-23-2005, 08:47 AM
  #870
dmatter's Avatar
DO NOT Try to Tighten the Eyelets to 1mm from the Shock Shaft! Just go 2mm And they Won't Leak around the Threads Due to the Bottom Spring Retainers. Pre Thread/Tap The Eyelets With A Screw From your Kit If You don't Your Shaft Or Eyelet Is Going to Get Boogered UP!!! THEY ARE TIGHT and it is hard to hold the Shaft While Threading They are So Tight!!!
dmatter is offline
