Like Tree1Likes
Xray T1FK05
Old 03-16-2005, 03:34 AM
  #661
kidDynomite's Avatar
Originally posted by Giuseppe d.
... in this and in X ray forum you'll get anwers form Tony, Martin Hudy, Mario Hudy, Gilles, Adreas and Anders Myrberg and some more people who for sure know the car far better than we.
Giuseppe, so true.
TonyV, just to let you know, your designer made some of the PDF downloads with crop-marks.
Also, on the '05 Set-up Sheet under "SUSP.HOLDER", what's the OPTIONAL=0.75? I didn't see it on the Optional parts list either. I also love the fact that you incorporated a spring chart as well. Great job! Can't wait to pick up my 05.
kidDynomite is offline
Old 03-16-2005, 04:29 AM
  #662
Andreas_Myrberg's Avatar
Optional 0.75 is to fine tune the rollcentre more, as it is now you can change the inner mounting of the A arms by 1.5 mm, but with this optional holder you can go halfway i you like. Also you can change anti-dive/kick up or anti/pro squat by 0.75 degrees now to. :-)
Andreas_Myrberg is offline
Old 03-16-2005, 04:39 AM
  #663
Originally posted by Andreas_Myrberg
Optional 0.75 is to fine tune the rollcentre more... by 0.75 degrees now to. :-)
Andreas, thank you much! I noticed that the basic rubber set-up had the arms in the middle roll-center holes. Would Joel's FK set-up (pro-dive & pro-squat) work with rubbers on the FK05?
Old 03-16-2005, 04:51 AM
  #664
Yes sure, both pro squat and anti dive can work very good on rubber tires. Both me and Joel used that on the T1FK. However we have not made a perfect setup for rubber tires yet. That is much more complex then foam tires. Me Joel and Viktor Wilck will go for a race this weekend and we will test a lot of setups so I'll report back to you about setups after the weekend.
Other wise the standard setup is a very good starting setup.
Catch you later
Old 03-16-2005, 05:39 AM
  #665
Anders Myrberg's Avatar
Default Re: Thick Chassies hopups and so forth
Hey guys,
best regards
Andreas Myrberg, the son/ driver, not the dad who's name is Anders ;-)
True!
Anders Myrberg is offline
Old 03-16-2005, 11:16 AM
  #666
S-T-R-l-K-E-R's Avatar
are the belts of the FK and FK05 the same (front and rear)?
S-T-R-l-K-E-R is offline
Old 03-16-2005, 12:26 PM
  #667
Yes they are
tonyv is offline
Old 03-16-2005, 03:22 PM
  #668
Just curious, has anyone tried springs from other manufactures on there Xrays. I have an 05 coming and my hobby shop doesn't support Xray (I'm going to try to change that) but they do have Schumacher, Associated and Losi springs. I also have some Losi springs from my xxxs. They are also cheaper than the Xray springs because have to buy them in a 4 pack.
Davenport is offline
Old 03-16-2005, 03:25 PM
  #669
prphze's Avatar
The 4 you get from xray are matched. Therfore your getting a better spring than you do from others. And I here congo springs from trinity work but, I have never tried them.
prphze is offline
Old 03-16-2005, 03:29 PM
  #670
rctoyguy's Avatar
Trader Rating: 21 (100%+)
The Associated springs as supposed to work - I hope so, since I just bought a set for my '05. I have been told that the XXXS springs are too big in diameter - this from a pretty reliable source. (A buddy that moved from Losi XXXS to XRay T1FK last year)
rctoyguy is offline
Old 03-16-2005, 07:35 PM
  #671
thanks for the info tony!!!
Old 03-16-2005, 10:27 PM
  #672
Speedo's Avatar
I like to stick with the Xray springs. They are available in such fine increments that I really don't see any reason to use anything else. Also, like a previous poster said, they are matched, or so Xray says.
Josh
Speedo is offline
Old 03-17-2005, 02:24 AM
  #673
buboy28's Avatar
Default Re: FKo5 parts now online
Originally posted by danjoy25
http://www.world-model.com/newproduct.html
More options to buy. the motor protectors looks good.
very nice indeed but better buy them at your local lhs, world-model distributes a lot of rc products unfortunately they only sell by the bulk. first time order should at least exceed HK$20,000.00 and thats a lot of dough
buboy28 is offline
Old 03-17-2005, 08:14 AM
  #674
I dyno/measured all my spring sets from all my cars and the Xrays were the most accurate, Kyosho second. So I sold the others. I would strongly suggest not putting Chevy springs on your Porsche.
Besides, we wouldn't be able to help you out with set-ups, because 30lbs Assoc. spring is not the same as 30lbs Xray. Oils differ too.
If you have a friend that may be getting an Xray too, why not split the spring sets. I never use four of the same color spring on my cars.
Old 03-17-2005, 08:29 AM
  #675
Catch you later
Sounds great, Andreas. Early next week I should have my 05 ready for stock setup testing. But I'm looking forward to you and the guys insight on alternative setups.
