Old 04-30-2007, 02:39 PM   #5356
heretic's Avatar
Originally Posted by Little Bahnatka
Anyone ever spend the $18 i did, and get one of these?
i wonder if the antiroll bar still reacts symmetrically if you succeed in benting it back to the normal shape?
heretic is offline   Reply With Quote
Old 04-30-2007, 05:11 PM   #5357
Jake S's Avatar
Trader Rating: 66 (92%+)
Send a message via AIM to Jake S Send a message via MSN to Jake S
Originally Posted by RoNTC3
Good to hear...my bad on the T4 oops...I'm getting blind in my old age
its ok Ron...hah understandable since the other two cars in my profile are tcs too. just trying to get a gt7 and a spektrum rx so i can get my t4 running at the same time i have my fk05 going, due to our local track putting in an indoor offroad track, so i can race tc and offroad year round, check it out any of you in the Rochester area, its RnDRacePark.com
VooDoo Racing Cells | Flying Farmer RC | Trackside Hobby | Prochko Paintz | RG1
Jake S is offline   Reply With Quote
Old 05-04-2007, 01:20 AM   #5358
Default How to add weight with a 3200 carbon li-po ?
Hi guys,
I've just bought a Team Orion Carbon 3200 Li-po battery. Great runs to come with my Mamba Max 7700 combo... well I guess.
Here is my question : any idea to make housemade weights to balance the car ?
Thanks for your answers.
Cheers.
Team Losi XXX-S G+ (Mamba Max 7700)
Team Losi XXX-4 G+ (Nosram Matrix 2005 & Storm 3 stars)
Team Xray T1 FK '05 (Nosram Matrix ISTC & Storm 3.5)
Team Orion Avionics Advantage / Team Orion Li-po 3200 Carbon Edition (5) / Futaba 3PK
Blin is offline   Reply With Quote
Old 05-04-2007, 07:57 AM   #5359
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Originally Posted by Blin
Hi guys,
Cheers.
Like every thing else in this hobby. Dig deep into the pocket, quarters, dimes and nickels.
Shoe goo it or servo tape it.
UN4RACING is offline   Reply With Quote
Old 05-07-2007, 11:01 PM   #5360
Jake S's Avatar
what do you guys run for droop in your fk'05s? im not really sure what to set the front and the rear too....also what ride-height?
btw this is for carpet foam
Old 05-07-2007, 11:10 PM   #5361
UN4RACING's Avatar
I run 2mm above zero in the front and 2.5mm above zero in the rear. With 2 degree toe in the rear. And zero toe in the front. I also found to get better off power steering with brushless the one way works good up to the 4300, any faster I like the diff.
Cyan, Magenta's. I start at 58mm and run 4.5 ride height.
Standard top deck and the 2.5 chassis.
Old 05-07-2007, 11:29 PM   #5362
Jake S's Avatar
got the 2.5mm in the rear, 2mm in the front, 2-deg rear toe, zero in the front....but i got the 3mm chassis and the wide top deck...lol also i have been running double-pink orange, and double pinks, i have been looking at the new parma cyans and magentas tho...ill use my pinks this summer tho lol
anyone know someone starting out that needs a cheap durable tc? trying to sell my irs tc3...$125 as a roller, $140 with a bunch of parts, and 2 sets of tires. would make a good first touring car for someone, as everyone has some setup knowledge of the tc3 lol and you can get parts for a tc3 for next to nothing, and even some tc4 parts fit (was thinking about adding the carbon fiber tc4 ft towers too it....
Old 05-07-2007, 11:35 PM   #5363
UN4RACING's Avatar
I'll PM you if I hear of any one. Personally I'm running dirt this summer. Ive been needing to get back out and let it ripp.
Just waiting on my T4.
Old 05-07-2007, 11:37 PM   #5364
Jake S's Avatar
t4 is such a nice vehicle, i wouldn't mind trading a pretty good tc (my tc3) for a ft b4 (or atleast one that has threaded shocks, titanium turnbuckles, some aluminum and some tires/parts) since i have an extra set of electrics (since tc is alittle slow in the summer heh
i just want to add Associated FT B4 to my signature then ill need to get another gt7 esc (have had such great luck with the gt7s), z590 servo (been good to me in offroad, z8800s in tc tho), and another spektrum receiver for my dx3 lol good thing the dx3 can hold 3 models, cause thats ill ill need, 2wd buggy, 2wd truck, 4wd tc not really a big fan of 4wd offroad as of late...
Old 05-08-2007, 05:28 PM   #5365
Jake S's Avatar
just got my gt7 with shorter wires (long wires went in the truck) into my fk05, ill get pictures up soon.
Old 05-08-2007, 06:39 PM   #5366
Jake S's Avatar
with the "new esc" it happens to still be a gt7 too
from the side you can see my custom antenna mount (using an old tc3 rear body post - same one i used for a transponder mount in my tc3) mounted to the servo again hah
still kept the battery wires long enough, for if i end up with a b4 for the offroad season, ill just need to splice in some wire for the motor wires
Old 05-08-2007, 08:51 PM   #5367
I've just fitted a Carbon 3200 in the '05. To make my clubs min. weight for Stock Rubber I need +170gr (6 oz for you guys).
Great Planes make lead weights (GPMQ4485). You need them 2 packs (about 28-29 pieces). They look butt ugly - so I'm think to wrap my mountains of lead in shrink wrap and cover that with Carbon Fiber sticker sheets.
I thinks thats what Nexus Racing did in their T2'007 mod article to fit a 4800 Platinum and it looked pretty good.
CaliberX is offline   Reply With Quote
Old 05-08-2007, 11:25 PM   #5368
RedRocketRacing's Avatar
Default FK05
Any of you who are still running the 05 (I am still running it too) want or need another roller? Or does is any one interested on an FK05? I have 3 of them and need to get money for an 007 conversion. Car is still very good. I dominated the NWIC this year in Stock Rubber with this car. Had a setup that I was able to run at all 4 of the races plus Regionals with very minor changes. I would compare it to the Numan Setup for the JRX-S. I have even ran it on ashpalt with similar sucess. Open to offer. Looking for $140 a car but will entertain offers. Have parts too. Pm if interested and will let you know what I have. Or if you are looking for something PM me.
RedRocket
Anders Hagen
Mastercard fresh off of Suspension
www.HomeRestorationsInc.com
Team West Coast Hobbies
NWIC 2008/09
RedRocketRacing is offline   Reply With Quote
Old 05-08-2007, 11:36 PM   #5369
Jake S's Avatar
ygpm rocket
Old 05-29-2007, 08:37 PM   #5370
Tire Chunker's Avatar
Trader Rating: 16 (100%+)
delete
Tire Chunker is offline   Reply With Quote
Xray T1FK05 $100.00 Charles R/C Items: For Sale/Trade 2 04-25-2006 10:51 AM
F/S: Xray T1FK05 ewippler R/C Items: For Sale/Trade 12 12-09-2005 04:03 PM
WTB: Xray T1FK05 ewippler R/C Items: Wanted to Buy 4 05-06-2005 06:40 AM
