Like Tree1Likes
Xray T1FK05
Old 11-12-2006, 06:58 PM
  #5326
rcracenut's Avatar
Trader Rating: 52 (96%+)
Or you can put the short black Associated TC4 ball ends on with the short black studs. This provides plenty of clearance with out cutting further into the arm. It doesnt pop off either.
rcracenut is offline
Old 11-12-2006, 08:26 PM
  #5327
Iceracer's Avatar
Thanks for the ideas. I really appreciate the answers. I'll put to bed the idea of mounting them on the inner (#1) hole. I guess if it was that easy, that's what they would have told us to do.
Any thoughts on knowing how much tension should be on the belt, aside from the adjuster being in the recommended position. I am wondering if over time the belt stretches and this has to be compensated for. How slack is too loose?
Iceracer is offline
Old 03-30-2007, 09:46 PM
  #5328
bretthitman's Avatar
Default xray
does any no if you can use a factory kit 04 diff on a 05 thanks Brett
bretthitman is offline
Old 03-30-2007, 09:57 PM
  #5329
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Yes you can use the diffs, but the one ways are different.
UN4RACING is offline
Old 03-30-2007, 10:33 PM
  #5330
thanks for the info UN4RACING
Old 03-31-2007, 05:40 AM
  #5331
ChrisP's Avatar
The T1FK (commonly referred to as FK04) used 32t diff pulleys.
The T1FK05 and newer used 34t diff pulleys.
Yes you can use the same diffs in both cars (The diffs are compatible with all Xray cars to date: original T1-current) you just need to ensure that you are using the correct pulley.
ChrisP is offline
Old 03-31-2007, 11:34 AM
  #5332
dynasty's Avatar
Trader Rating: 28 (100%+)
i need an FK05 chassis.. anykind. let me know if you have one. thanks
dynasty is offline
Old 03-31-2007, 02:23 PM
  #5333
UN4RACING's Avatar
I sure hope he catches this before he puts one in?
I let that slip my mind. Hopefully he knows about the internal ratio differences?
Old 04-01-2007, 01:03 AM
  #5334
i will rember to change them i hope
Old 04-01-2007, 05:03 AM
  #5335
i want to sell my fk05 im wondering how much i can sell it for reasonably?
topekoms is offline
Old 04-26-2007, 06:42 PM
  #5336
Jake S's Avatar
Trader Rating: 67 (93%+)
i just bought one for $160 with some parts....
Jake S is offline
Old 04-26-2007, 10:09 PM
  #5337
Jake S's Avatar
gosh, i need to get a 1/16th allen L-WRENCH to work on this xray hah...also since i lost my 3mm hex driver, i need to get another for these HUGE shock screws....all in all, i can't wait for sunday to use it, my irs tc3 looks alittle sad sitting over on the table right now, but hopefully i can find it a new home.
Jake S is offline
Old 04-27-2007, 05:06 AM
  #5338
RoNTC3's Avatar
After 1 lap around the track, you'll be finding a new home for that TC4 as well.
RoNTC3 is offline
Old 04-27-2007, 07:02 AM
  #5339
Jake S's Avatar
if you read carefully it says ft t4 d-azz lol
Jake S is offline
Old 04-28-2007, 12:11 AM
  #5340
Jake S's Avatar
my new baby!
Jake S is offline
