Like Tree1Likes
Xray T1FK05
Old 06-09-2006, 04:18 PM
  #5266
For those 2 particular items, yes, XRay is the only manufacturer. However, Team Tamale makes the aluminum C-Hubs, steering blocks and rear carriers for the car out of 7075 aluminum. Much lighter and stronger than the XRay pieces. They also make 7075 chassis stand offs (the posts that connect the upper and lower deck)
Tony
RcCzarOfOld is offline
Old 06-16-2006, 05:13 AM
  #5267
RoNTC3's Avatar
I'm trying to replace my steering blocks and the axle is flared on the end and won't slide through the bearing. Anyone else have this problem and how did you fix it without buying a new axle?????
RoNTC3 is offline
Old 06-16-2006, 05:44 AM
  #5268
Joep's Avatar
But the best solution in the end are the hudy steel axles
Joep is offline
Old 06-16-2006, 05:50 AM
  #5269
RoNTC3's Avatar
Thnx, It worked. I'm going to look into the steel axles.
RoNTC3 is offline
Old 06-16-2006, 05:52 AM
  #5270
Joep's Avatar
Joep is offline
Old 06-16-2006, 06:11 AM
  #5271
I filed the edges and then replaced them with the steel ones.
SRW141 is offline
Old 06-16-2006, 08:53 AM
  #5272
Iceracer's Avatar
How essential is the thicker chassis and wider upper deck to carpet racing? Will a beginner like me appreciate the difference? Can you run the wider upper deck without the thicker chasssis, or is that dumb?
Iceracer is offline
Old 06-16-2006, 08:59 AM
  #5273
I always run the kit chassie and upper deck. I bought a wider deck to try this coming season. The wider deck stiffens it, so it doesn't flex as much under the high bite conditions.
SRW141 is offline
Old 07-29-2006, 02:51 AM
  #5274
Hi guys,
Message to anybody who is running Platinum 4800 Li-po,
Can we still use the Xray carbon battery holder ? Is not the battery holder too wide and hides the plugs of the Platinum 4800 Li-po ?
Thanks for answering me.
Cheers.
Blin is offline
Old 08-01-2006, 06:35 AM
  #5275
Originally Posted by Blin
Hi guys,
Cheers.
Anybody ?
Blin is offline
Old 08-01-2006, 06:48 AM
  #5276
RoNTC3's Avatar
I don't know anyone that runs LiPo's.
RoNTC3 is offline
Old 08-01-2006, 08:59 AM
  #5277
Trader Rating: 22 (100%+)
you can get away without the thicker chassis, but you will want the wide top deck.
fastasu2 is offline
Old 08-07-2006, 02:49 PM
  #5278
stonedgti's Avatar
Trader Rating: 15 (100%+)
If anyone has a dog bone to sell, let me know.
[email protected]
stonedgti is offline
Old 08-15-2006, 06:54 AM
  #5279
Darkside Motorsports is now manufacturing replacement outdrive sets for the X-ray T2 and FK'05 Sedan Cars. These outdrives are machined from aircraft grade aluminum and hard coat anodized black. They are a direct replacement for the kit stock outdrives. They are part number #450 with a retail price of $41 per set and are available directly from the Darkside Motorsports website at www.darksidems.com
THE DARKSIDE is offline
Old 08-31-2006, 07:03 PM
  #5280
MadMikeB's Avatar
Default Max Pinion Size
Howdy,
Can anyone tell me the maximum pinion size you can run with a standard FK'05 84T 48P Spur gear? I have a race tomorrow, my car is at home and I need to know if I need to hit up the shop at lunchtime for another spur gear.
Mike
MadMikeB is offline
