Old 05-09-2006, 02:53 PM   #5236
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Originally Posted by dogenia
Besides the obvious price and material difference, whats the advantage of getting titanium over stainless steel?
Do the stainless steel srews strip as well? Do the titanium ones NOT strip?
Thanks,
Don
They all have the potential to strip depending on the hardness of your tool if used improperly.
Stainless is least likely because it is stronger than steel but it is also heavier than steel.
Titanium is as strong as steel but it is lighter than steel.
Example: Weight Titanium < Steel < Stainless
Strength Titanium = Steel < Stainless
YR4Dude is offline   Reply With Quote
Old 05-09-2006, 04:33 PM   #5237
the_barbarian's Avatar
Originally Posted by GTTurbo
Does anyone know where I can get the Titanium screws for the FK05??? Does it exist?? Sick of stripping the stupid aluminium screws!!! Wanted to get rid of it once and for all!!
Or maybe even steel screws? Anyone? Thanks.
Dinball on ebay has a range of titanium screws
http://search.stores.ebay.com/Dinbal...095710QQsofpZ0
the_barbarian is offline   Reply With Quote
Old 05-10-2006, 07:30 AM   #5238
Location: Curacao, Netherlands Antilles, Dutch Caribbean
Send a message via AIM to dogenia Send a message via Yahoo to dogenia
Default Titanium vs Steel
Ok this is what I get from the great input from all you wonderful people on this board:
Stainless Steel is the way to go for hardness
Titanium is a lighter weight but the chance to strip is still there.
How about the black anodized screws that Xray sells for the original T1?
http://www.teamxray.com/teamxray/pro...366&kategoria=
Now for the next question: What would be proper technique to get these screws out in one piece?
Xray T2 in 19 turn spec class, Novak GTX, Sanwa M8
dogenia is offline   Reply With Quote
Old 05-10-2006, 07:47 AM   #5239
Iceracer's Avatar
Make sure you use a proper fit of screwdriver to avoid marring the heads. Try some different sizes. I could be wrong on this, but anything I've had that was titanium, seemed a good bit harder than aluminum, so I'm not sure its fair to lump them together as equally prone to stripping the heads.
I know the manual for my associated car says to use lubricant whenever a thread goes into aluminum, but dry for plastic parts.
You may be able to use a drill to remove the V of a countersunk head, separate the two parts, then work on the shaft that remains. There's likely not enough to slot and use a flat bladed driver, so you may have to file a flat on the shaft and use a mini vice-grip locking pliers. You may end up simply replacing / sacrificing the least expensive part.
Iceracer is offline   Reply With Quote
Old 05-10-2006, 09:16 AM   #5240
Send a message via AIM to RcCzarOfOld Send a message via MSN to RcCzarOfOld Send a message via Yahoo to RcCzarOfOld
To get out a stuck screw, put a few drops of WD-40 around the head and let that sit for a few. Then hold the tip of your soldering iron to the head of the screw for a few and it should come out pretty easily. However, if you've already stripped the head, use your dremel with a cutoff wheel and make a slot in the head of the screw and use a flat screwdriver after applying heat and WD. Also, you could get the corally screws and replace the hex heads of the Xray with those. The Torx head screws pretty much just plain don't strip.
Tony
RcCzarOfOld is offline   Reply With Quote
Old 05-10-2006, 08:59 PM   #5241
woozer71's Avatar
Trader Rating: 23 (96%+)
Has anyone tried a 63t(48p) spur in 27turn stock and if so how did it go?
Fraser Coast RC Car Club/FCRCCC
VBC D06 / Xray T4 2013
Yokomo BMax2 ver 2 - Tamiya F104 x1
Sanwa MT-4
woozer71 is offline   Reply With Quote
Old 05-10-2006, 10:11 PM   #5242
CarbonWorks's Avatar
I'm not sure if there is still a worldwide shortage of FK05 2.5mm chassis', but I still manufacture an exact replacement. Precision CNC machined 2.5 mm quasi-isotropic carbon fiber. 65.00 shipped to the USA. Email me if interested. I will ship worldwide, but its more like 73.00. My chassis is exactly the same, but the battery slots have been revised to accept the 3800's and 4200's better.
Mike
[email protected]
CarbonWorks is offline   Reply With Quote
Old 05-11-2006, 04:46 PM   #5243
Default serpent shocks
blin check your pm
mshap33 is offline   Reply With Quote
Old 05-12-2006, 12:36 AM   #5244
Originally Posted by the_barbarian
the most important upgrade on the fk05 is steel axels on the front the standard one always end up buring then you cant get them out of the knuckle
[IMG]/305315.jpg[/IMG]
part number 305315
also the motor guard part number 303060
[IMG]/303060.jpg[/IMG]
and the battery strap part number 306162
the fk05 battery holder has been superseeded by the T2's one part number 306163
[IMG]/306163.jpg[/IMG]
Sorry to have pulled the plug on the pictures, but this forum is too popular. Everyone who visited the page with this post saw pictures from www.teamxray.co.uk and we were having a large increase in bandwidth use.
Cheers
Griff
You can see the pictures at the following addresses. This way you can see the parts if you want to know what they look like, but those who know what they look like will save us bandwidth.
http://www.teamxray.co.uk/productdetail-305315.php
http://www.teamxray.co.uk/productdetail-303060.php
http://www.teamxray.co.uk/productdetail-306162.php
or now
http://www.teamxray.co.uk/productdetail-306163.php
xray_griff is offline   Reply With Quote
Old 05-15-2006, 09:50 AM   #5245
Default Gearing
Hey guys I would appreciate some advise on gearing here.
Currently running 112x28 but out of the corners the car is a bit sluggish.
Personally I'm thinking go up to a 115x28 but what do you experts say?
Don
Old 05-15-2006, 09:56 AM   #5246
94_snake's Avatar
That will deffinetly give you a little more out of the corners, but if you have real long straights, you will top out a little earlier. How long are your straights and is it a technical or flowing track?
94_snake is offline   Reply With Quote
Old 05-15-2006, 09:59 AM   #5247
kerry's Avatar
what are you running foams, rubber? what motor?
kerry is offline   Reply With Quote
Old 05-15-2006, 10:59 AM   #5248
Default gearing
Sorry here goes the setup:
Xray FK05, 19 turn spec class, foam 26 mm 40 shore, treated track, long flowing straights, short parts technical. Mostly straights though. It takes bout half a straight to get up to speed, I would like maybe a fourth of the track to accomplish this feat?
Don
Old 05-15-2006, 11:12 AM   #5249
kerry's Avatar
peaking out around 1/2 way to 3/4 down the back straight should be about right.any sooner and you run the risk of over heating the motor. try to find out what the rollout of motor and tire size should be and adjust from there. if your not sure ask someone at the track what there gear ratio and rollout is using the same brand of motor and that should help you figure yours out. my suggestion and thats all it is would be to go up one pinion and see how that feels i always like my motors toping out 3/4 down the back straight. hope this helps
Old 05-15-2006, 12:11 PM   #5250
Iceracer's Avatar
Does anyone wrap their battery slots with insulating tape? Unnecessary overkill?
Xray T1FK05 $100.00 Charles R/C Items: For Sale/Trade 2 04-25-2006 10:51 AM
F/S: Xray T1FK05 ewippler R/C Items: For Sale/Trade 12 12-09-2005 04:03 PM
WTB: Xray T1FK05 ewippler R/C Items: Wanted to Buy 4 05-06-2005 06:40 AM
