Xray T1FK05
#5131
The past two race meets i have had problems with bearings seizing, these being brand new straight out of pack xray ones. One i took apart one of the balls had come unseated and was stuck between the two "plates" which they should ride in. This is only happening with the front steering blocks and rear hubs also, the bearings seize up, get very hot from running (must happen when racing). This was happening and i wasnt hitting anything at all, nice big open track.... Any idea why this has happened (3 bearings now) my old ones that i took out and kept incase i needed them work fine.
#5132
Thanks for the help on the caster blocks guys. I already have a P-Dub front
bumper. Most of the time the breakage is from a sideways hit on the boards when exiting a corner. I'm going to raise the rear rollcenter to see if it gives me more corner exit steering. That and try to hit the boards less!
#5133
I've got the last of my FK05 parts listed on ebay:
http://search.ebay.com/_W0QQsassZkal...QQfsooZ1QQrdZ0
#5134
#5135
TeamGP? Anyone back from snowbirds on the xray team want to comment?
#5136
Whats the recomended foam tire diameter for best performance?
#5137
I shoot for right around 2.2"- 2.3"dia.
#5138
#5139
How tight should i have my front long and me rear short belt on my FK05?? Is that why in getting a faster wear on my front tires because one belt isnt adjusted right? Is there something to measure the tightness or just go by teh feel of it? my fronts are usually .5-.7mm smaller
#5140
At a normal club race we start in the 2.3 to 2.25 range
Brad its normal for the fronts to wear faster then the rears... just foam tire racing
#5142
#5143
Originally Posted by JWerks
#5145
Originally Posted by teamgp
