Like Tree1Likes
Xray T1FK05
Old 01-28-2006, 08:27 AM
  #5101
ChrisP's Avatar
The FK05 manual describes how to modify the arms to get some clearance for 28mm foams using the outside holes...
another trick that I did on my FK05 was to go to my local industrial tool supply shop and pick up a de-burring tool... (small hooked blade on a swivel in a bic-pen style handle....about $3) and use that to bevel the inside edge of the wheels manually....it gave just enough clearance that the rubbing ceased to be an issue...
ChrisP is offline
Old 01-28-2006, 11:00 AM
  #5102
Rogier,
The Serpent shocks are great. Great look and smooth performance.
Unlike the Xray shocks, the Serpent ones are easy to fill up and it is easier to have the same rebound on the 4 shocks. They fit perfectly on the T1 FK'05 (same screws) and the Xray springs too.
Here are some fotos of Serpent shocks on my T1. Enjoy.
Cheers.
Blin is offline
Old 01-28-2006, 06:58 PM
  #5103
Mark G's Avatar
Originally Posted by Blin
Rogier,
Cheers.
looks good
Mark G is offline
Old 01-29-2006, 01:27 AM
  #5104
Rogier's Avatar
Rogier,
Cheers.
Really looks good! I think I'm going to order some for my FK05. Also the alloy looks good! How is the brushless motor in the FK05??!!
Rogier is offline
Old 01-29-2006, 05:07 AM
  #5105
Rogier,
Well, the Nosram brushless system handles like a dream : more than 45 packs and it performs as day one. It's fast (i would say like a 11 turns), durable and the runs last longer.
I've cleaned it once and there was just a little dust (wich is normal because I mainly run on parking asphalt). I love this system because it performs very well (with right ratio) with (almost) zero maintenance.
I have a 12X2 Team Orion Revolution on my Pro 4... It also performs well but I have to clean it every 7 or 8 runs to keep a good performance. It's boring me more and more... I think that I'm going to purchase a brushless system for my Pro 4 too.
Bonus : one more picture of the Serpent shocks.
Cheers.
Blin is offline
Old 01-29-2006, 05:33 AM
  #5106
Mad Hatter's Avatar
Default 960 shocks...
I have been looking, obviously in the wrong spot. Where can I find the 960 shocks? I am assuming the X-ray springs fit them?
Mad Hatter is offline
Old 01-29-2006, 06:11 AM
  #5107
Well, here is the (German) shop where I buy most of my Xray parts. The commercial service is very good. Shipping is fast and cheap (at least for Belgium).
The link : http://clark-s.de/
The Xray screws and springs fit perfectly. No extra hardware is needed to mount the Serpent shocks on the T1.
Cheers.
Blin is offline
Old 01-29-2006, 01:07 PM
  #5108
R/C Tech Elite Member
BSchorr's Avatar
Trader Rating: 100 (100%+)
Hey, I got a very nice FK05 off rctech a few weeks ago, and ive gone throught everything check out the settings and different crap
my question is.... It has 30wt xray shock oil all round. When it comes time to rebuild and maintance the shocks, is it the same wt as a losi 30 wieght? Everyone runs like a 50front 40 rear or a 70 front or 50 rear something like that. is it the same? 30 seems kinda low?
BSchorr is offline
Old 01-29-2006, 01:31 PM
  #5109
J@UNE's Avatar
Its not the same as losi and I really suggest using the xray 30w oil all around, Way easyer to follow drivers setups and the 30 is proven for any kind of racing ruber and foam... I know its different but it seem to be the way to go.
J@UNE is offline
Old 01-29-2006, 02:31 PM
  #5110
r0adrunn3r's Avatar
Yep - I will second that. Just use the XRay 30wt all round...
r0adrunn3r is offline
Old 01-29-2006, 02:44 PM
  #5111
Scottmisfits's Avatar
But if the shops won't get you the Xray oils, it's close to AE 50 weight. That's a little thinner than the Losi 50. The Losi 47.5 is about the same as the AE 50.
Scottmisfits is offline
Old 01-30-2006, 03:15 PM
  #5112
Mark G's Avatar
hey ive nocied that my diffs are starting to get a bit grity and not so much nice and smooth, i tryed rebilding my diffs and added some diff lube. I also nocited the mettle ring had a slite line all the way around it. would that be my problem should i get new rings part #(305082)????
thnxs
-Mark
Mark G is offline
Old 01-30-2006, 07:32 PM
  #5113
Mark, This is andy I was at IRP on sat. next to you with the little kid. Anyway, just try to rebuild the diff and make sure everything is clean also you can flip the diff rings to the other side.. I dont know if irp stocks the rings but I have an extra set if I see you there next sat. also try the niftech diff lube it seems to work the best
Andy C is offline
Old 01-31-2006, 04:01 AM
  #5114
stinkypop's Avatar
If your diff is gritty check your thrust bearings, especially if they are the soft ones.
stinkypop is offline
Old 01-31-2006, 04:46 AM
  #5115
Mark G's Avatar
okay andy thxs I try thos things. yeh I rember you from RSJ
Mark G is offline
