Like Tree1Likes
Xray T1FK05
Old 12-13-2005, 07:04 PM
  #4831
Originally Posted by Mdoc
I doubt you will find it posted yet Art....you might ck over at the Xray site tho....
Already did. Nothing there yet.
Art Jensen is offline
Old 12-13-2005, 07:08 PM
  #4832
Trader Rating: 29 (100%+)
I didnt think it was, but I hadnt looked for a few days....if I spot it any where Ill leave a post here saying where.....
Mdoc is offline
Old 12-13-2005, 07:18 PM
  #4833
Default new to xray
I just received my fk05 in the mail does anyone have good setup sheet for bumpy meduim traction asphalt?
also where is a good place online to get parts for xray?
thanks
Joe
gomeztx is offline
Old 12-13-2005, 08:37 PM
  #4834
Trader Rating: 42 (100%+)
PRS Spurs.
I bought a PRS 116 Spur thinking it would fit with no problems...
When mounted it rubs the motor mount. Has anyone else had this happen??
Nexus is offline
  #4835
Old 12-13-2005, 08:58 PM
  #4836
Pauls setup is listed in Dumas setup from cleveland. If you look close there are two of Duma's setups from cleveland pauls is the first one.
bigdog is offline
Old 12-13-2005, 09:04 PM
  #4837
kidDynomite's Avatar
Originally Posted by Nexus
PRS Spurs.
Nexus, I had this prob before when the car first came out. I took a sharpie to the motor mount and traced out the spur. Then took it to the bench grinder and shaved it a hair.
You still have my springs, right? Just make sure Rookie doesn't borrow them.
kidDynomite is offline
Old 12-13-2005, 09:08 PM
  #4838
I did the same thing, but used a die grinder instead of a bench grinder
Mdoc is offline
Old 12-13-2005, 09:12 PM
  #4839
Alex C's Avatar
Trader Rating: 50 (100%+)
PRS Spurs.
Nexus.....if you are truly using a PRS 116 Spur gear....it should not rub at all.
Try to measure your sideplay on your layshaft...to see if there is something wrong with your bearing retainers, or layshaft bearings.
Also....try using RW spur gears, I believe they have them @ IRP.
I hope this helps Nexus.
Best Regards
Alex Cortez
Alex C is offline
Old 12-13-2005, 09:14 PM
  #4840
Alex, good job at the Hurricane race!
Old 12-13-2005, 09:17 PM
  #4841
It "truly" is a PRS gear I bought from IRP.
It still rubs...I guess maybe I can sand down the inner portion of the spur or something.
Hell I'll just keep running 48P!! It's easy to set mesh LOL :P
KidDyn...I have your springs and will try to catch up with you this weekend. If not I'll mail them to you or something.
Nexus is offline
Old 12-13-2005, 09:19 PM
  #4842
Alex C's Avatar
Thanks...for the props brother!!
Best Regards
Alex Cortez
Alex C is offline
Old 12-13-2005, 09:23 PM
  #4843
Alex C's Avatar
Nexus...we all run the PRS 64 Pitch Pro-Lite Touring Gears, see attached link to PRS http://www.precisionracingsystems.com/products/10
Perhaps they may have changed the mold.....made it a wider in width????
Also try the RW Gears!!
Alex
Alex C is offline
Old 12-13-2005, 09:28 PM
  #4844
Talking
Don't do that. Then you'll have to shave every replacement spur. JK, man. That'll work too. I haven't had to touch mine since last season.
No worry's about the springs. We'll see each other. It's not likey my cop friends are going to rip me off or something. BUT... if I don't see you before your baby comes... then yes, please mail them.
Old 12-13-2005, 09:31 PM
  #4845
Does anyone run the 3mm chassis with IB3800s?
Does the battery slots need to be shaved more to compensate?
Does anyone know where I can get a good deal on a new or slightly used 3mm? Thanks!
