Like Tree1Likes
Xray T1FK05
Old 12-03-2005, 02:11 AM
  #4801
Originally Posted by Midnight
You can only get the new one 06.
i know of at least two shops in uk that have stock so why can he not get a new one???
Cartman is offline
Old 12-04-2005, 12:28 AM
  #4802
JohnMatrix's Avatar
Looking at some of the set up sheets, I noticed the use of foam in the shocks, could any one explaine this to me, what part # the foam is and where it goes?
Thanks.
JohnMatrix is offline
Old 12-04-2005, 04:15 AM
  #4803
teamgp's Avatar
Thanks.
The Shock Foam Inserts are installed inside the cup of the rubber membrane bladder, beneath the upper composite mount. They help the shocks to rebound quicker which normally results in greater traction over bumps and quicker steering transitions.
teamgp is offline
Old 12-04-2005, 03:25 PM
  #4804
teamgp's Avatar
FYI,
One-way / Carpet / Foam Setup update
"...my second 3rd place finish in a row and coming within one second of making TQ..."
teamgp is offline
Old 12-04-2005, 06:47 PM
  #4805
can't wait for a shootout between the 05 and t2............if the difference is within a fraction of a second, i will laugh all winter
then again the msx refine is a much more nimble car then the 415,so i will expect similar performance gains for T2...then again did tamiya copied Yokomo..........??????????
erric_13 is offline
Old 12-04-2005, 07:03 PM
  #4806
Bob-Stormer's Avatar
What's it worth to you to easily change a spur gear at the track, or lets say a belt? What if it's the largest event you attend every year. What's missing your most important race of the year worth to you because you need to fix something fast that can't be fixed fast? depends on your perspective. If I had flown to a larger event, and discovered a real problem that required a serious overhaul fast, and I was unable, take the cost of your hotel, add in your airfare, entry fees and meals, time off from work, general aggrivation, and you'd get an answer that is higher in value than the car. I'm gonna run one (or two), just because it was desgined to be easier to work on. That's worth more to me than anything. Make my life a little easier.
Bob-Stormer is offline
Old 12-05-2005, 03:47 PM
  #4807
Midnight's Avatar
Trader Rating: 87 (100%+)
How long before the 06 comes out?
Midnight is offline
Old 12-06-2005, 07:50 AM
  #4808
Cool Battery strap for T1FK05
Does anyone know where I can buy the battery strap for the 05. All the fuss about the new car and they do not have parts avail for the older cars!! Help please.
Farmers Agent is offline
Old 12-06-2005, 08:20 AM
  #4809
That's all I need,,,,,a fraction of a second per lap to lap you and take the gold
Since the 415 and '05 have similiar layouts I think that a comparison between them is comparing apples to apples. Of course the Xray has a better design on the little things(main shaft keyed not set screwed) and higher quality materials(spring steel).
The easy access to diffs is a bonus, the real upgrade is corner speed- by the lowering of the center of gravity. This made a big difference to the 415
Charles is offline
Old 12-06-2005, 08:25 AM
  #4810
Now if Xray would copy the DJ Pro Module that would be a sweet Christmas present. The pro module rocks on asphault!!!!!!!!!!
Merry CHRISTMAS everybody
Charles is offline
Old 12-06-2005, 08:43 AM
  #4811
jt6
jt6's Avatar
Try http://www.ashfordhobby.com/
jt6 is offline
Old 12-06-2005, 09:03 AM
  #4812
Since the T2 and the 415 are near copy cats. You might be able to put DJ's suspension on the T2. But, xray's are always so dialed I personally don't know why you would want to.
Does anyone know if the new car will chatter with a front spool? The new design is more in line with all the other cars that chatter.
Juan Aveytia is offline
Old 12-06-2005, 12:02 PM
  #4813
vtl1180ny's Avatar
I'm currently a little ticked off that there's another new car coming out... I too have been trying to find the battery strap and now it looks like I never will.... I'm about to sell off all my xray stuff and get out of 1/10th on road for good....
vtl1180ny is offline
Old 12-06-2005, 12:13 PM
  #4814
Thumbs up Found xray battery straps
I posted "where to find 05 battery straps". A post was put up to call ashford hobby shop, He did not have it!!!. . Call Keith at RC SCREWS 734-765-8870. He has tons of parts in stock for the xray. corally and all 1/12 scale lines he says. I ordered the strap and the stainless screw set for the 05.
Old 12-06-2005, 12:41 PM
  #4815
kerry's Avatar
you will still be able to get parts for the t1 platform. xray will never turn there back on existing customers. granted its an exotic car because parts are made in europe and takes awhile to get to hobby stores, if you want parts availability buy an associated, trust me you will miss the quality as soon as you open the package. i know its frustrating but if your selling your stuff and getting out because of this, IMO your half way out the door before. dont use this as the final push. check with some canadian distributors. i have seen them on the self myself. if you need some numbers let me know i would be glad to help.
kerry is offline
