Like Tree1Likes
Xray T1FK05
Old 11-26-2005, 09:07 PM
  #4741
Number 11's Avatar
You tell um Pezz Dag Burnit!
Number 11 is offline
Old 11-26-2005, 09:31 PM
  #4742
teamgp's Avatar
FYI,
One way Carpet/Foam setup UPDATE
"...simply put, the car holds the line mid corner better and steers more consistently all around..."
teamgp is offline
Old 11-26-2005, 09:36 PM
  #4743
teamgp's Avatar
Originally Posted by rpoage
If you are looking at some of the team set-up sheets and you see 3.0mm it's because a lot of the team guys use the full ball cup from the EVO-2 and they have a built in 2.0mm(apx) before adding a shim.
Quite right. I use the ball cups myself. They are extremely strong for their thin shell, even after popping them off more than several times to change the shims.
teamgp is offline
Old 11-27-2005, 09:12 AM
  #4744
Trader Rating: 55 (100%+)
Default Help with assembly
Hey, I was wondering if someone could help me out here. I am assembling my T1FK'05 and have found that the belt always wants to ride to the far left hand side of the front diff gear. This puts it very close to the steering post that goes from the lower chassis to the upper deck. It's not touching when I rotate the drive train by hand but it's REALLY close. I am using a wide upper deck and the 3MM chassis (I don't know if this matters). Is this normal? Is there a way to adjust where the belt rides on the gears? Any help would be greatly appreciated.
Scott
rccars4scott is offline
Old 11-27-2005, 09:17 AM
  #4745
make 1005 sure your belt tensioners are the same and not making the diff out of line
Cartman is offline
Old 11-27-2005, 02:46 PM
  #4746
Trader Rating: 14 (100%+)
Hey guys I'm looking for a new FK05 any suggestions on where I might find one on line. Went to Xray's website and went down the dealer list with no luck as far as online shops go. Thanks in advance.
rushrush1 is offline
Old 11-27-2005, 02:50 PM
  #4747
Let's start the process of elimination...
What country are you in?
TraceRacing is offline
Old 11-27-2005, 02:57 PM
  #4748
Scho's Avatar
Scho is offline
Old 11-27-2005, 03:00 PM
  #4749
Sorry US
Old 11-27-2005, 03:37 PM
  #4750
Trader Rating: 17 (100%+)
Xray FK05 Mod Carpet 1, 2 and 3 finishes.....good job.
Solara is offline
Old 11-27-2005, 03:41 PM
  #4751
hpipro321's Avatar
Originally Posted by rushrush1
Sorry US
Ultimate Hobbies....www.ultimatehobbies.com
RC america...www.rcamerica.com
Dinball.......www.rcmart.com
heres 3
hpipro321 is offline
Old 11-27-2005, 03:57 PM
  #4752
kerry's Avatar
check out www.stormerhobbies.com
kerry is offline
Old 11-27-2005, 04:06 PM
  #4753
I looked at ultimate already, no listing for fk05 (I'll call them tomarrow)
RC america- kinda pricey 438.00
Dinball- kinda far away(never delt overseas)
Stormer - not in stock
thanks guys
Old 11-27-2005, 04:19 PM
  #4754
Originally Posted by kerry
I brought the last FK05 from Stormer....a month ago, and still, box is not open yet as of today......
Solara is offline
Old 11-28-2005, 12:34 AM
  #4755
try going to ebay they always have some at a good price.
ptjonesus is offline
