Like Tree1Likes
Xray T1FK05
Old 11-25-2005, 11:01 AM
  #4726
Trader Rating: 14 (100%+)
Hi,
you can try
www.onroadracing.com
Rich has been keeping everything updated and has links to al the sites.
TimXLB is offline
Old 11-25-2005, 06:34 PM
  #4727
What is the cheapest place online to buy X-ray replacement parts??
ghuber is offline
Old 11-25-2005, 07:46 PM
  #4728
RayWarner's Avatar
You can try kthobbies.com They offer fast shipping and great prices. (When you can find Xray parts )
RayWarner is offline
Old 11-25-2005, 09:16 PM
  #4729
Bob-Stormer's Avatar
Got mine cleaned up.
Attached Thumbnails Xray T1FK05-fk05_body5.jpg   Xray T1FK05-fk05_2.jpg   Xray T1FK05-fk05_1.jpg
Bob-Stormer is offline
Old 11-25-2005, 10:28 PM
  #4730
Trader Rating: 17 (100%+)
Gary YGPM.
Jamie Corrado is offline
Old 11-25-2005, 10:29 PM
  #4731
dawgmeat's Avatar
Originally Posted by Jamie Corrado
Gary YGPM.
How did it go at Hobbychamber tonite, I had to work
dawgmeat is offline
Old 11-26-2005, 05:59 AM
  #4732
Rob Phillips's Avatar
anyone know if the alum rear hubs are the same as the composite ones. I wonder if that could be why my wheels rub the screw when using a 3mm shim.
Rob Phillips is offline
Old 11-26-2005, 08:26 AM
  #4733
rraden's Avatar
Trader Rating: 257 (100%+)
Does anyone know if the one-way front diff from the FK 04 version will fit in the FK 05 car?
rraden is offline
Old 11-26-2005, 08:49 AM
  #4734
That is one good looking body...........and so...."CARBON FIBER" too....good job.
Solara is offline
Old 11-26-2005, 08:58 AM
  #4735
kerry's Avatar
dont fit
kerry is offline
Old 11-26-2005, 10:49 AM
  #4736
Scrad's Avatar
Trader Rating: 16 (100%+)
The one way bearings are backwards. If you could pop the old bearings out of the 04 oneway and re-install them the opposite way it would work. I haven't tried to get he bearings out, so I'm not sure if it is possible.
Scrad is offline
Old 11-26-2005, 12:35 PM
  #4737
rpoage's Avatar
They are the same size. On a 05 about the thickest shim you can run is a 2.0mm but the 1.5mm is safer depending on who's rims you use. If you are looking at some of the team set-up sheets and you see 3.0mm it's because a lot of the team guys use the full ball cup from the EVO-2 and they have a built in 2.0mm(apx) before adding a shim.
rpoage is offline
Old 11-26-2005, 07:08 PM
  #4738
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
Unfortunatley parts have been a little hard to come by. However we did get a small shipment in of arms and caster blocks and some other stuff. We should have the website updated tomorrow sometime.
Kraig
KT Hobbies
Kraig is offline
Old 11-26-2005, 07:45 PM
  #4739
The Fog's Avatar
One way from the 4 works on the 5 if you cut a pully down and use the core as a shim, just need 2mm longer bolts and away ya go.
Jacko
The Fog is offline
Old 11-26-2005, 08:47 PM
  #4740
Pezz's Avatar
I know I have said this before, but here it goes again.....
HEY RC AMERICA!!! GET SOME PARTS IN I AM TIRED OF NOT HAVING PARTS FOR MY CAR. And no I don't want to order them from some hobby store in another state. My LHS is back ordered on parts because RC America can't deliver the goods. GET YOUR SHIZNITCH TOGETHER!!! I need parts.
Thank you..
-B
Pezz is offline
