Like Tree1Likes
Xray T1FK05
Old 11-23-2005, 11:52 AM
  #4711
Trader Rating: 17 (100%+)
Originally Posted by imprsme
One thing I noticed is that the camber link locations are not marked anyone know which ones Mike ran?
upper middle for the front
lower in the rear
Jamie Corrado is offline
Old 11-23-2005, 12:23 PM
  #4712
ottoman's Avatar
Has anyone tried the inboard verses out board rear toe... what is the difference in handling between the two?
ottoman is offline
Old 11-24-2005, 02:47 AM
  #4713
FlyinRazorback's Avatar
Has anyone tried Dumas' set up from asphalt Nats?
FlyinRazorback is offline
Old 11-24-2005, 07:42 AM
  #4714
hpipro321's Avatar
it was ok i didnt really care for it
hpipro321 is offline
Old 11-24-2005, 08:09 AM
  #4715
polesitter61's Avatar
Razorback - Try Ralph Burch's set up from the asphalt nats, I've been using it as a starting point at two different tracks and it is really good right out of the box. Only changes I made were to shorten up the wheelbase a little for the tighter corners, and last race I had to move the front shocks in a hole for a little more turn in. It's by far the best set up I've ever had on my FK05 for asphalt.
polesitter61 is offline
Old 11-24-2005, 08:42 AM
  #4716
Trader Rating: 29 (100%+)
Originally Posted by Rob Phillips
Anyone using Peter Robinsons carpet setup? I thought this would be a good place to start.
I have found one problem though, the setup calls for the shocks to be run in the outside position on the arm and to use a 3mm shim under the rear hub camber link, so now the wheel rubs in both places. It is only slightly rubbing in both spots, just wondering what you guys have done to fix this.
he was running the 2 degree aluminum rear hubs, they give more room for the shocks by turning the rear of the wheel away from the back of the arm, and might be a bit shorter.......
Mdoc is offline
Old 11-24-2005, 08:43 AM
  #4717
FRB.....you need to be looking at carpet set ups
Mdoc is offline
Old 11-24-2005, 01:18 PM
  #4718
acutts's Avatar
A few pics of my FK05 with dual cool can fan installed
acutts is offline
Old 11-25-2005, 04:16 AM
  #4719
Default Overdrive
Hi, have any of your guys try the overdrive on your xray. I thought of trying it by putting a 32 gear on the front one-way and 34 gear on the rear ball diff. I heard about this on on-road gas car which give you a higher speed on the straight. Let me know if any of you have try it.
thesaint is offline
Old 11-25-2005, 09:20 AM
  #4720
DavidAlford's Avatar
Trader Rating: 32 (100%+)
Well Xray has the top 3 spots in mod at Cleveland right now. Nice to see Paulie with a good car.
DavidAlford is offline
Old 11-25-2005, 09:33 AM
  #4721
true David...and did you notice, Dumas and Burch are the only two cars, at this point anyway, turning laps in the 11's consistantly
Mdoc is offline
Old 11-25-2005, 09:36 AM
  #4722
Xray got a steal when they got Paul. Kyosho made a big mistake.
Old 11-25-2005, 09:49 AM
  #4723
definatly.....I was glad to see you make the move also lol
I dont really know you except from online, Im a friend of pooky and bigdog
Mdoc is offline
Old 11-25-2005, 09:53 AM
  #4724
Regional Moderator
BHenderson's Avatar
Well MDoc Im not sure I'd say that in public if I were you lol. Hope to see you two guys tomorrow.
BHenderson is offline
Old 11-25-2005, 11:45 AM
  #4725
rcracenut's Avatar
Trader Rating: 52 (96%+)
Does anyone know where you can view the race results for Cleveland?
rcracenut is offline
