Like Tree1Likes
Xray T1FK05
Old 11-23-2005, 05:10 AM
  #4696
Rob Phillips's Avatar
Anyone using Peter Robinsons carpet setup? I thought this would be a good place to start.
I have found one problem though, the setup calls for the shocks to be run in the outside position on the arm and to use a 3mm shim under the rear hub camber link, so now the wheel rubs in both places. It is only slightly rubbing in both spots, just wondering what you guys have done to fix this. Thanks Rob
Rob Phillips is offline
Old 11-23-2005, 05:11 AM
  #4697
Oh yeah, what Losi oils compare to 30 and 20 weight xray oils? 60 and 50?
Old 11-23-2005, 05:13 AM
  #4698
one more q, which thrust bearing came with the car that was bad?
Old 11-23-2005, 06:59 AM
  #4699
DavidAlford's Avatar
Trader Rating: 32 (100%+)
I ran the Dumas setup from vegas with the 3mm shim and it didn't rub. I moved the rear shocks in one hole top and bottom. Car was very hooked up.
DavidAlford is offline
Old 11-23-2005, 07:28 AM
  #4700
teamgp's Avatar
Rob,
Will you be running this weekend? I can help you out if you like as I'll be in for practice most of the afternoon on Friday and in early on Saturday for the race.
The 3mm shim shouldn't be rubbing, unless the rim is warped or of a smaller inside diameter. Moving the upper and lower shock mounts in one hole will work well, just keep in mind that the rear will be a little softer overall. Going up 2.5lb in the rear spring rate will bring it back closer to the previous feel.
teamgp is offline
Old 11-23-2005, 08:05 AM
  #4701
I have to work all this holiday weekend including tomorrow, so I won't be able to race this weekend or next weekend. I hope to get out to the track to try my new xray out. It will be hard pressed to find another TC that can handle aswell as my Losi.
Old 11-23-2005, 08:10 AM
  #4702
the wheel is rubbing on the screw, I was thinking about dremeling it down a little. I think running outboard tow will also give the tires a little more clearance from the shock eyelet. I have yet to pick up any 2* carriers yet. Are they available in composite or just alum?
Old 11-23-2005, 08:17 AM
  #4703
imprsme's Avatar
Trader Rating: 91 (100%+)
Where is everyone getting Dumas' Vegas set-up? I only see his Carpet Nats. Set-up on the RC America site.
imprsme is offline
Old 11-23-2005, 08:39 AM
  #4704
I got it from the xray forum where all the setups are.
Old 11-23-2005, 08:50 AM
  #4705
imprsme's Avatar
LOL I called myself looking thru that. I will go see if I can find it.
imprsme is offline
Old 11-23-2005, 09:02 AM
  #4706
imprsme's Avatar
OK the only 2 set-ups I see from Mike are the Carpet Nats and the asphalt nats.
The only Vegas set-ups I see are Jilles and Joel.
Are they in a forum and not listed in the "set-up sheets" page? If so can someone point me in the right direction, page number or which forum its in.
Thanks!
imprsme is offline
Old 11-23-2005, 09:13 AM
  #4707
I got it on my laptop. I try and post it at lunch.
Old 11-23-2005, 09:52 AM
  #4708
J@UNE's Avatar
It's not there anymore...
J@UNE is offline
Old 11-23-2005, 10:23 AM
  #4709
Man what would you people do without me lol
Old 11-23-2005, 10:34 AM
  #4710
imprsme's Avatar
One thing I noticed is that the camber link locations are not marked anyone know which ones Mike ran?
imprsme is offline
