Like Tree1Likes
Xray T1FK05
Old 11-14-2005, 09:49 PM
  #4621
Roger's Avatar
Originally Posted by MDawson
CVD Blades
I had a lot of wear on CVD blades with the use of a spool. Are there any mods or fixes for this? It seems they need to be replaced every 2 runs or so.
The material seems too soft.
Whats up Mark. Unfortuantely, there are no upgrade for the plastic blades for the FK05 yet. When I ran a spool, I went through the same issue; replacing the blades ever 2 runs or so. For now, just keep them stocked up in your parts bin. I remember I bought so many blades, that I literally had about 20 or more sets.
How's Chris doing with his FK05 ? I sent him afew set-ups.
Roger is offline
Old 11-14-2005, 10:00 PM
  #4622
Trader Rating: 27 (100%+)
Thanks Roger. They seem to tear at the eyelet. I might have to look at the other Manf. that make the blades and see if something fits.
I have not had a mod car that was this good in a long time.
CL stuff is looking really strong.
MDawson is offline
Old 11-14-2005, 10:11 PM
  #4623
Speedo's Avatar
Originally Posted by Rookie Solara
Thank you very much...I am running 3mm chassis, so I will pick up the 120T, but I can only find 116, 118, 124, 126, 128 thru places like KT, EAMS or Speedtechrc......no 120.
What about 2.0mm for outdoor...?
PRS's website has them in stock.
I am not sure about the 2mm chassis. A 120 tooth 64p spur is exactly equivilent in size to a 90t 48p spur. The 84 that came with the kit is equivilent to 112t in 64 pitch. 87t 48p = 116t 64p. Not sure if that will help you figure it out or not. I would say 112t to be safe, although a 116t may fit.
Josh
Speedo is offline
Old 11-14-2005, 11:09 PM
  #4624
FlyinRazorback's Avatar
CVD Blades
I've noticed the blades tend to last a little longer by using small rubber o-rings in the outdrives.
FlyinRazorback is offline
Old 11-15-2005, 02:19 AM
  #4625
CVD Blades
This is whole idea behind the drive shaft blades, they are ment to wear out. the drive shafts and out drives take a lot of punishment when using a spool and would wear out quick, so these plastic blades go in and take the abuse instead.
Dan Reynolds is offline
Old 11-15-2005, 06:46 PM
  #4626
RAD Dog Racing's Avatar
Is there an aftermarket replacement part for the bottom shock ball joint. I am running 28 mm foams and keep braking them. I don't want to buy any more of the 308310 kits just to get this part. It would be nice to find some sturdier ones or should I just get different shocks.
RAD Dog Racing is offline
Old 11-15-2005, 07:01 PM
  #4627
rpoage's Avatar
Serpent SER 909403's are just the 5.8mm ball end in a package of 4. Cheaper than XRA308310's but not a cheep as not hitting anything?
rpoage is offline
Old 11-15-2005, 07:38 PM
  #4628
the_barbarian's Avatar
just use the shock ends from a Pro4 and ditch the ball joint all together they are much smaller and dont hit the wheels
the_barbarian is offline
Old 11-15-2005, 09:56 PM
  #4629
Team EAM
Trader Rating: 79 (100%+)
Depending on the size of the track you probably wont be able to get a big enough pinion on the motor with a 120 spur unless you run mod. Most guys on carpet run a 114 or 116. Depending on how much 19 turn you run. 19 turn motors require a bigger pinion than a stock so I ususally use a 114 everywhere to be safe. Mod guys have to run a 116 or 118...I dont know of any that run 120's.
EA
EAMotorsports is offline
Old 11-15-2005, 10:04 PM
  #4630
Trader Rating: 17 (100%+)
EA
EAM....thanks, I think I will pick those up from your site.....thanks for the head up.
Solara is offline
Old 11-16-2005, 12:05 AM
  #4631
kidDynomite's Avatar
Rookie, everyone at IRP is pretty much running the 116T.
kidDynomite is offline
Old 11-16-2005, 12:47 AM
  #4632
wolfman76's Avatar
OK, How hard is it to remove the rubber seal from bearings. I would like to clean them up and re oil then replace the rubber seal. I've done metal shield bearings before, is there much difference.
wolfman76 is offline
Old 11-16-2005, 02:29 AM
  #4633
I ran my new X-Ray for the first time today and i have to say i'm VERY pleased with it! So easy to drive and very smooth through the turns.
I'm only racing 540 atm but are there anything i need in the way of hopups? I got told to get a HPI spring set over the X-Ray one because the X-Ray springs are so expensive. I got told that sway bars won't make much of a difference? Is this true?
I've been out of the hobby for 5 years and this is the first i'm i've driven anything RC in that time and after only 4 packs i was right on the pace of the top 540 guys at the club, just my consistanty isn't there yet
Love the car!
~AR~ Gizmo is offline
Old 11-16-2005, 02:59 AM
  #4634
Birky's Avatar
I ran my FK05 for the first time last weekend and I found it great as well. The only hopups I got were one of the spring sets, and if you don't like taping batteries (like me), also get the battery brace. Apart from that I don't think the car needs hopups.
Birky is offline
Old 11-16-2005, 03:34 AM
  #4635
Spud_J's Avatar
Agreed Dan but a set of blades nearly every run while running 7 turns with a spool at most Nationals is a bit extreme. A fractionally more durable plastic would help, our Xray ones resemble moulded chewing gum! Schumacher blades for instance I believe are about right.
Spud_J is offline
