Like Tree1Likes
Xray T1FK05
Old 11-13-2005, 07:09 PM
  #4606
Originally Posted by Static_racing
Thanks john, I have a 30 Tooth in it now, if thats too hot I'll make adjustments. The Brood race is at Mimi's on Sat and I have 2 new Experss motors and 2 "Extreme" stock packs. I couldnt believe the voltage these things were coming off at. I can't wait for people to ask, "what the hell you got in that thang?"-
29 gives you a rollout of 25.9mm 30 gives a 26.8, I have a monster stock and I've found that something around 27mm is a good starting point for that motor
cvt01 is offline
Old 11-13-2005, 10:43 PM
  #4607
Trader Rating: 17 (100%+)
To 48P or 64P spur gear...? Before I build my 05, I want to know should I buy the 116 64P spur gear (good luck finding one...everywhere is BO) or use the stock 48P gear....? Any CON of using 64P on 05?
Since I have 20-38T 64P pinion collection for my previous and current 12 scale, and I do not want to collect another set of 48P just for the 05.....
I am going to run indoor carpet for now....may be some outdoor asphalt next year......please advise, thanks.
PS...where can I find PRS 116T 64P spur...? And is 116T the one to get? What other should I try..?
Solara is offline
Old 11-13-2005, 10:57 PM
  #4608
Default Car pick
I am uncertain between Xray and the RDX as to which is a better car. I am getting back into the hobby after a year lapse and I am in the market for a new car. Most of the guys at my track are running the T1FK05 but I hear a lot of talk of the RDX as being a better car. Can someone tell me the main advantage of chosing the x-ray over the rdx?
Thanks!
JB
ravex is offline
Old 11-13-2005, 11:01 PM
  #4609
JohnMatrix's Avatar
RDX is a very good car, but so is the Xray. I would say its 50 50.
The real big difference, durablity. Xray hands down is a much stronger car. It breaks 10 times less than a RDX.
JohnMatrix is offline
Old 11-14-2005, 02:26 AM
  #4610
I just got back into the hobby after a 5 year lapse. I got the xray. Parts are cheeper for it which is a big bonus. And from what i hear it's a better car. I know someone that's sold a cyclone and rdx to buy the fk05 and he says it's the best of the lot. I'm still yet to drive mine.
~AR~ Gizmo is offline
Old 11-14-2005, 05:27 AM
  #4611
VenomWorldOrder's Avatar
shyt! , i'm still buying second hand fk04's you can pick them up real cheap now though, basically got it for $90 australian, if i end up selling all the stuff that came with it
VenomWorldOrder is offline
Old 11-14-2005, 05:28 AM
  #4612
rcracenut's Avatar
Trader Rating: 52 (96%+)
I would stay with the 64 pitch. EA motorsports has them in stock.
rcracenut is offline
Old 11-14-2005, 10:54 AM
  #4613
Nice...thanks, but...I am running indoor foam, 19T or mod....what T should I get, or what are the top 3 choice...? start with 116T? Thanks
Solara is offline
Old 11-14-2005, 05:27 PM
  #4614
hey im going to go get my fk05 later this week and im runing stock foam and rubber do i need to pick up more parts to run that
Matthew.H is offline
Old 11-14-2005, 08:22 PM
  #4615
Speedo's Avatar
If you're running the 3mm chassis, pick up a few 120t PRS spurs. If 2.5mm, 116t.
Speedo is offline
Old 11-14-2005, 09:39 PM
  #4616
andrewdoherty's Avatar
Trader Rating: 49 (100%+)
mattman-
youre going to want to swap out the yellow and white springs for something stiffer like light purple and lavander. Find a set up on the xray forums or ask a local who drives an xray what they run. Then you'll have a better idea if you need to buy different c hubs etc.
andrewdoherty is offline
Old 11-14-2005, 09:47 PM
  #4617
thanks
Old 11-14-2005, 10:05 PM
  #4618
Trader Rating: 27 (100%+)
CVD Blades
I had a lot of wear on CVD blades with the use of a spool. Are there any mods or fixes for this? It seems they need to be replaced every 2 runs or so.
The material seems too soft.
MDawson is offline
Old 11-14-2005, 10:33 PM
  #4619
I bet you will get your car done way before me...my car is still collecting dust, hope to see you at IRP....btw, where are you going to run your 05?
Here is where I know my carpet foam setup....
http://www.teamxray.com/xforum/viewtopic.php?t=1315
And i know most of the ppl at IRP are using something very similar to that, may be a little bit different due to the personal preference (driving style) but not far off.....here are the basic foam carpet setup, and I hope you got the RcAmerica edition 05...that will save you atleast $100...
1.) Foam/carpet racing:
To adjust the T1FK'05 for foam racing we suggest the use of these optional parts:
Part#.....Description
301113...3.0mm chassis
301165...Wide Upper Deck
306510...Alu Top Deck Mounts (pair)
302160...Front Lower Arm Hard
303160...Rear Lower Arm Hard
302329 & 302330...4.5 HARD
302095...Foam Front Shock Tower
302251...Composite Steering Block Right 3 Holes
302261...Composite Steering Block Left 3 Holes
308396...Violet (28lb) Spring Set
308397...Purple (33lb) Spring Set
P-dub or Parma foam bumper
Xray FK05 front ball diff (if you have the US spec, it came with the car)
Parma Magenta 28mm foam (front) True to 58mm
Parma Plaid 28mm foam (rear) True to 58mm
Solara is offline
Old 11-14-2005, 10:35 PM
  #4620
Thank you very much...I am running 3mm chassis, so I will pick up the 120T, but I can only find 116, 118, 124, 126, 128 thru places like KT, EAMS or Speedtechrc......no 120.
What about 2.0mm for outdoor...?
Solara is offline
