Like Tree1Likes
Xray T1FK05
Old 11-11-2005, 01:12 PM
  #4576
RCknight's Avatar
Default Anyone have an idea how to get the proper clearance
so that the spring clears the 26mm foam tires? I filed down the nub per the instructions, but it still rubs on the tire. I'm afraid if I cut more than the instructions say there will not be enough material for the screw. Not only that, but then the shock angle gets way off. What do you guys do?
RCknight is offline
Old 11-11-2005, 01:14 PM
  #4577
imprsme's Avatar
Trader Rating: 88 (100%+)
Originally Posted by John Tag
IMPRESME is my..PB....
In your dreams!
imprsme is offline
Old 11-11-2005, 01:19 PM
  #4578
imprsme's Avatar
Doesn't the instructions tell you to "tap the Hole" then cut away the nub completly?
From the instruction book it shows a "red" line that indicates where to cut. It is flush with the arm.
Or you can just run the inside hole..
imprsme is offline
Old 11-11-2005, 01:32 PM
  #4579
J@UNE's Avatar
I usually go furter than the red line like 1.5 or 2mm in the arm and drill the hole furter.
I'm now using the 2deg inboard toe-in rear hub and have way more clearence so I guess cuting the arm at the red line would be good enough.
J@UNE is offline
Old 11-11-2005, 02:21 PM
  #4580
Rob Mincey's Avatar
I haven't verified this, but supposedly the 2 degree outboard rear hubs will allow you to run the outside hole on the arm with foam tires. Can anyone confirm?
Rob
Rob Mincey is offline
Old 11-11-2005, 05:50 PM
  #4581
hpipro321's Avatar
Rob
I think they do becuae ur lowering in the blocks so the screw will barely make it
hpipro321 is offline
Old 11-11-2005, 05:55 PM
  #4582
Default xray
where can i find a xray in stock?
LILROBBY is offline
Old 11-11-2005, 05:56 PM
  #4583
imprsme's Avatar
There is a GREAT DEAL in the forsale forum....
http://www.rctech.net/forum/showthread.php?t=90254
imprsme is offline
Old 11-11-2005, 06:48 PM
  #4584
the_barbarian's Avatar
Hi I want to try a ball diff in the front of my FK05 does wnyone know if a FK04 rear diff will fit in the front of an FK05
thanks
the_barbarian is offline
Old 11-11-2005, 07:29 PM
  #4585
Scrad's Avatar
Trader Rating: 16 (100%+)
yes the 04 diff will work in the 05.
Scrad is offline
Old 11-11-2005, 07:31 PM
  #4586
thanks
You need to use a different pulley. The FK 04 uses a 32 t pulley, while the fk 05 uses a 34 t pulley.
071crazy is offline
Old 11-11-2005, 08:04 PM
  #4587
thanks i'll take the pulley off the multi diff
  #4588
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by L.Fairtrace
Thats the only reason I put Tamiya Shocks on my car. They never feel the same. Believe me the Tamiya shocks definatley work on the xray, but it took me trying a lot of different parts to get them to be the right length and whatnot.
L.Fairtrace... sent you a PM about the shocks. thanks!
Hebiki is offline
Old 11-11-2005, 08:19 PM
  #4589
axel's Avatar
Default WHEEL NUTS
I just saw a pic on xrays website that a guy has an xray that has regular wheel nuts than the practical xray wheel screws. Anybody know a reliable way of doing this mod?
axel is offline
Old 11-11-2005, 08:39 PM
  #4590
howard hudson's Avatar
I dont see a reason why to do it. example xray wheel screw nice and flush. Wheel nuts stick out and catch on things such as lane borders and such
howard hudson is offline
