Xray T1FK05
#4546
No matter how flat my bottom chassis was, whenevr I installed the Top Deck, it would cause the chassis to tweak. So bad that pushing on one side would cause the other side to lift up. Itried everything to eliminate the problem with no luck. I finally installed 4 counterunk washers on the rear 4 screws and bingo, no more bowing of the chassis. I am using the stock chassis and top deck.
Anybody else have this problem? How did you remedy it?
#4547
Does anyone have a good set up for the base 2.5mm chassis car?
#4549
Whats the part # and name of the serpent shocks everyone is talking about?
And who has them in stock?
Thanks.
Thanks.
#4550
Thanks.
Thanks.
Part: 903165
$50 a pair x 2 = expensive......
http://www.mytsn.com/products/desc.asp?prid=4156
But I ordered 1 set for my 950R....I ordered from Ashford Hobbies, ask for Robert.....
Only thing I am not sure is....2 rear..? I thought it is 2 front....? I might be wrong, and most likely.....I am.
#4552
Originally Posted by dgullickson
3x8 thrusts with carbide balls on special at www.axiommotors.com
EA
#4554
Originally Posted by Nexus
Anyone know any online shops that have the FK05 front foam shock tower in stock?
#302095
kt and speedtech are out.
#302095
#4555
What is the advantage over the stock thrusts?
Yeah, it's definitely two sets of rears.
#4556
Losi will be releasing a set of 4 for $62.00 from what I understand. Heres a pic and they work great.
#4557
Originally Posted by Rookie Solara
Shock-set RCC rear (2)
Part: 903165
Part: 903165
Is there a part number for a shock rebuild kit for those shocks?
Thanks,
Mark
#4558
I don't understand why so many people are changing the shocks that come with the kit! The shocks are very easy to build, don't leak, adjustable with the clickers and reliable... If it isn't broke why fix it??? I know Ralph Burch, Jilles Groskamp, the Myberg brothers, Bobby Flack, Peter Robison, Jarrod Scott and myself all use the stock shocks that come with the car.
#4559
We would like to announce that the handout tire selection for the 2006 ROAR On Road Electric Paved Nationals hosted by Speedworld Raceway has been made. The tire selected is the RP36L supplied by Shumacher USA. We would also like to announce our current list of class sponsors; Touring Car Modified, presented by RC America/Xray, Touring Car 19 Turn Spec, presented by Schumacher USA, Touring Car Stock, presented by EA Motorsports. As always up to date information regarding the nationals can be found at http://www.2006RoarNats.com.
#4560
Hey all, I'm running a FK05 with a stock motor, I have a 120T spur 58mm tires. I dont know if the internal ratio is still 1.7 or not. I have larger pullies on my diffs. What is a good starting point for roll-out and what pinion should i use? Thanks!
