Like Tree1Likes
Xray T1FK05
Old 11-08-2005, 08:43 PM
  #4531
axel's Avatar
I wish I had seen this back when I was assembling mine...the only ugly looking thing on my xray are the scratched up shock rods. Now I need to buy 4 new shock rods=approx. $19. And the part #970050 ( the O-rings) anyone know where to get these speedtech is sold out.
axel is offline
Old 11-08-2005, 09:01 PM
  #4532
Registered User
xrcbuggy's Avatar
Try Stomer http://www.stormerhobbies.com Part#XRA970050
xrcbuggy is offline
Old 11-09-2005, 12:25 AM
  #4533
RCknight's Avatar
Default Anyone have the part numbers for those Serpent...
shocks? Do you need two sets of rears? Man, I dislike the stock shocks after having some JRX-S ones.
RCknight is offline
Old 11-09-2005, 05:32 AM
  #4534
Originally Posted by 7below
When I first tried to thread the shock ends on, I had a problem too. So what I ended up doing was not installing the piston like the instructions said. I installed the e-clip that goes below the shock piston and then stuck the shaft through the bottom and buit the seal. I was then able to grab the shock shaft through the top of the shock where the shaft is flat. It made it worlds eaiser for me. Hope this helps.
Thanx for that. It worked for me
~AR~ Gizmo is offline
Old 11-09-2005, 08:20 AM
  #4535
jamescam's Avatar
This Team Tamale tool is a must have for any tool box. Not only will it keep you from scratching your XRay Shock Shaft, I use it when building any shocks.
jamescam is offline
Old 11-09-2005, 08:33 AM
  #4536
Trader Rating: 42 (100%+)
Anyone know any online shops that have the FK05 front foam shock tower in stock?
#302095
kt and speedtech are out.
Nexus is offline
Old 11-09-2005, 08:43 AM
  #4537
#302095
Have you tried the "thercshack.com"
SRW141 is offline
Old 11-09-2005, 08:50 AM
  #4538
#302095
Also check stormerhobbies.com
SRW141 is offline
Old 11-09-2005, 08:57 AM
  #4539
Registered User
xrcbuggy's Avatar
#302095
Hello to Chicago, IL
Is Stomer Hobby unknown to this site (one of the big distributer in US) find the web address 5 post above your post. He..He...He.
Part #XRA302095 they have 6 in stock
xrcbuggy is offline
Old 11-09-2005, 09:08 AM
  #4540
Registered User
xrcbuggy's Avatar
Hi to all,
I just got this car & trying to learn about it as quickly as possible.
If you like & want to give me a heads up, I appreciate that too.
Now my question, is there a 3rd party MFG who make parts for this beautiful car.
xrcbuggy is offline
Old 11-09-2005, 10:07 AM
  #4541
fpart's Avatar
Trader Rating: 40 (100%+)
Originally Posted by rraden
My LHS had them in stock over the weekend, Larry's Performance R/C. Best to call them, 586-997-4840, located in Metro Detroit, MI. The kits on the shelf had both 3.0 and 2.0 chassis in them. Tell them Russ sent you.
Thanks a lot I ordered one!!
fpart is offline
Old 11-09-2005, 10:42 AM
  #4542
Originally Posted by xrcbuggy
Hi to all,
Team Tamale makes various aluminum pieces for the fk, rear hubs, caster blocks, steering blocks, spring cups, among other pieces... check out his site www.teamtamale.com
brians11 is offline
Old 11-09-2005, 11:39 AM
  #4543
Twin-Kyle's Avatar
As long as the scratches are not too deep, put the shafts in a Dremel and use 1500 to 2000 grit WET sand paper to remove the scratches.Then use a good polish to bring back that nice XRay shine.(What have you got to lose,shafts are screwed anyway )
While I was learning how to build the shocks,I scratched one, Did above,and used the shaft.This was over 6 months ago.No leaks,works fine(by the way,mine had two rather deep scratches in it.) and still use that shaft today.
Don,t spend all that money on new shafts if they can be fixed!!!
Twin-Kyle is offline
Old 11-09-2005, 12:05 PM
  #4544
Registered User
xrcbuggy's Avatar
Thank You Sir,
Very nice stuff.
xrcbuggy is offline
Old 11-09-2005, 12:32 PM
  #4545
Speedo's Avatar
Yep two sets of rears.
Speedo is offline
