Like Tree1Likes
Xray T1FK05
Old 11-05-2005, 08:40 PM
  #4486
howard hudson's Avatar
Originally Posted by CRASH
Basically you can use either Xray or PRS with no mods. Anything else and you will have to drill the third hole. Not difficult by any means but the PRS spur gears and pinions are the best out there in my opinion.
Later,
kimbrough gears work also just a lil bit wide tho. but never had one rub . PRS is by far the best choice
howard hudson is offline
Old 11-05-2005, 08:58 PM
  #4487
JimmyMac's Avatar
Yeah, I couldn't find any PRS spurs in stock anywhere. So I went with a Kimbrough 116 (biggest pinion for this is a 37 tooth). It fits. But remember this. The Kimbrough spur is off set. So if you put it on wrong, it'll rub. However, putting it on the right way.. the numbers on the spur (in this instance it's the 116) will slightly rub the motor mount. That's how close/clearance is. Just sand it down and it's all good. Now I just gotta find some PRS gears in stock.....
But yeah, wish they made a 4 screw spur mount. That would be nice.....
JimmyMac is offline
Old 11-05-2005, 09:15 PM
  #4488
John Tag's Avatar
Trader Rating: 42 (100%+)
Hey Jimmy what ya runing with a 37T...A slave 55T motor and 54 mm tires
John Tag is offline
Old 11-05-2005, 10:05 PM
  #4489
sharkman's Avatar
Trader Rating: 18 (100%+)
If you still want prs, try www.teammaximus.com
Heath has them in stock, plus plenty of xray stuff.
sharkman is offline
Old 11-05-2005, 10:08 PM
  #4490
Team EAM
Trader Rating: 79 (100%+)
I'll have more 112-118 PRS gears in stock on Monday. They just finished up a run of them.
EA
EAMotorsports is offline
Old 11-05-2005, 10:52 PM
  #4491
JimmyMac's Avatar
No goofball... I was test fitting them to see if I can run 19t with it..
Thanks for the update Eric. I checked out your site first when I was looking for them. But you were out and so was everyone else. I'll order 114 and 116 on Monday then...
JimmyMac is offline
Old 11-05-2005, 11:44 PM
  #4492
Roger's Avatar
MDawson: check your PM
Roger is offline
Old 11-06-2005, 12:36 AM
  #4493
Joep's Avatar
The new extra hard Xray spurs are now available. They are awesome.
Joep is offline
Old 11-06-2005, 01:08 AM
  #4494
JimmyMac's Avatar
64pitch or just 48....?
JimmyMac is offline
Old 11-06-2005, 11:27 AM
  #4495
axel's Avatar
I'm not sure if this is true or not, but does xray give you the updated thrust bearing for free if you call in and say you have an earlier fk05 kit? Anybody know the part number?
axel is offline
Old 11-06-2005, 07:31 PM
  #4496
New ride. Complete with ugly practice body. Just finished and had to show someone.
Attached Thumbnails Xray T1FK05-100_2540.jpg   Xray T1FK05-100_2541.jpg   Xray T1FK05-100_2542.jpg   Xray T1FK05-100_2543.jpg   Xray T1FK05-100_2544.jpg
Art Jensen is offline
Old 11-06-2005, 08:27 PM
  #4497
Speedo's Avatar
Nice ride! Where did you find that fan mount?
Speedo is offline
Old 11-06-2005, 08:32 PM
  #4498
Thanks alot. I made the fan mount out of a piece of scrap graphite and an Xray top plate post. I can't wait until Sunday.
Old 11-06-2005, 09:32 PM
  #4499
They sent mine over for free of charge. Follow the steps on this link:
http://www.teamxray.com/teamxray/new...ce0e6a304d116d
skinart76 is offline
Old 11-06-2005, 10:00 PM
  #4500
axel's Avatar
thanks
axel is offline
