Xray T1FK05
#4321
Originally Posted by cvt01
Asso 50 oil has the same "weight" as xray 30
#4325
from what i know, xray 30 is equal to assoc. 60-70
#4327
#4328
If anyone is looking for an FK05 "RC America Edition" Stormer Hobbies has them in stock
#4330
Originally Posted by hpipro321
not really its more like 40 weight
#4332
Originally Posted by DOTMAN
NOt sure about the weight but my car sucked with XRAY 30wt. I replaced it with Ass 30 and the car came alive
XRAY 35wt oil is similar to AE/Trinity 80wt. I've tested this with the shock length tool and its what I run for foam/carpet now.
#4333
Originally Posted by teamgp
...another with 50wt Trinity oil and bled them to the same rebound length...
Basically, it seems that for every 5 points for XRAY oil, you can move 25 points in Trinity oil.
#4334
Originally Posted by kerry
het teamgp what effect does moving the bottom rear shock mount have from inside hole to outside hole
With past T1 models having more weight over the rear end, using the outer position kept the rear end more consistently stable. But with the FK05's slight front weight bias, the inside holes work fine.
