Like Tree1Likes
Xray T1FK05
Old 10-25-2005, 07:34 PM
  #4291
dado11g's Avatar
end of this month is what i heard, but i went there last weekend and they were open...
dado11g is offline
Old 10-25-2005, 09:37 PM
  #4292
Speedo's Avatar
Is there supposed to be a shim on top of the front bulkhead? I just finished putting my FK05 together, and the front bulkhead is a little less than 0.5mm lower than the top deck. This causes the top deck to warp when tightened down.
Speedo is offline
Old 10-25-2005, 10:07 PM
  #4293
howard hudson's Avatar
Mine was the same way when i put it together. what I found out was that the upper bearing cap for the steering was not seated all the way in the upper deck> A lil tap and all was good
howard hudson is offline
Old 10-25-2005, 10:19 PM
  #4294
Speedo's Avatar
I did check that...I'll have to look at it again.
Speedo is offline
Old 10-25-2005, 10:30 PM
  #4295
Speedo's Avatar
Aha! Problem solved. Thanks
Speedo is offline
Old 10-26-2005, 08:27 AM
  #4296
rraden's Avatar
Trader Rating: 257 (100%+)
Originally Posted by rdub202
when is larrys opening the track back up marshal?
Larry's opened up racing on Friday's two weeks ago. No Sunday's as of yet.
rraden is offline
Old 10-26-2005, 01:40 PM
  #4297
dado11g's Avatar
ok, sounds right. i like rc screwz more though, i went to larrys for parts the other day and peeked in at the track(its been a while), its soo f'ing tiny!!! i like the bigness of rcs
dado11g is offline
Old 10-26-2005, 06:34 PM
  #4298
Speedo's Avatar
My set of Serpent shocks came in the mail today. They are a good design and the quality is fairly good. I wouldn't say they are worth $100 but whatver, I would probably pay more than that to not have to use Xray's shocks.
Looks like they should bolt right on with a few modifications to the shock end.
Speedo is offline
Old 10-26-2005, 11:19 PM
  #4299
axel's Avatar
i'm not sure if this is new or old news but I saw this pic of a prototype chassis...I assume it's just the bottom plate rather than a new car...looks to have more flex.
http://images.google.com/imgres?imgu...lr%3D%26sa%3DN
The pic is under Alex Hagberg's car towards the bottom of the left column.
axel is offline
Old 10-27-2005, 12:01 AM
  #4300
jamescam's Avatar
That is interesting, perhaps the same thinking as the adjustable top deck.
jamescam is offline
Old 10-27-2005, 02:38 AM
  #4301
It looks like the one they used at the Euro's when the track was really wet
Dan Reynolds is offline
Old 10-27-2005, 11:47 AM
  #4302
lbckevin's Avatar
Trader Rating: 105 (99%+)
Here is the Direct link to the chassis:
xray chassis
lbckevin is offline
Old 10-27-2005, 11:50 AM
  #4303
HRCRACER123's Avatar
Trader Rating: 33 (100%+)
Hey Guys this might be a dumb question but I just had a spending spree and bought the following and will changing all this stuff when I get it in. I am going from a
2.5mm chassis to a 3mm
standard top deck to a wide one
3 degree c hubs to 4.5
I am also going to put on a front roll bar 1.5mm
I race on high bite carpet with foam tires. What should I expect? Easier to drive? Better cornering?better transitioning? I just dont know what to expect. I know it should make my car better but not sure in what area's.
HRCRACER123 is offline
Old 10-27-2005, 12:02 PM
  #4304
jt6
jt6's Avatar
Along with his questions.....what is the difference with the front shock tower for foam tires from the one that comes with the kit?
jt6 is offline
Old 10-27-2005, 12:05 PM
  #4305
lbckevin's Avatar
Front shock tower for foams is lower.
lbckevin is offline
