Xray T1FK05
#4276
Originally Posted by nutfluff
the spring cups are locked down into the eyelets....just following a set-up sheet posted by Jim Bishop? from the Xray site...any suggestions?
#4277
Originally Posted by prphze
The 4 springs you get from Xray are matched. Therefore your getting a better spring than you do from others.
OR, the whole springs production but under the same color are identical to each other ?
I have two package of Xray light blue and they are mixed now
#4278
i have a fk04 diff being used in a xray and i find that no matter how tight i do up the diff before a race it becomes ultra loose by the end of the race?
why is this so? i have recently re built it used almost no grease and even after totally re-building it it doesn this?
could it be the plastic nut retainer is worn out? or is it soemthing else? i am using a stock motor.
#4279
I would say that either your diff screw is stripped or the plastic nut retainer is worn out.
Rob
Rob
#4280
#4281
Got my team tamale lowered shock collars today, quick and cheap delivery worldwide, i believe they were posted Friday, and to make it to me by Tuesday is pretty damn impressive, ill get them fitted later
Edit: Got them fitted and the car is SLAMMED! 2.5mm ride height all around from, what was 5.5-6mm using Tamiya shocks and unknown ballends.
#4282
where can i get an xray fk05 layshaft online?
#4283
speedtech seems to sell them but they appear to be out of stock...
http://www.speedtechrc.com/store/ebp...id=197&id=5235
#4284
Would using a high roll center with 0 anti squat cause me to not be able to lower my ride height below 7.5????
#4286
All right guys, just received my new FK 05 kit, it included a 2.0/3.0 chassis, three hole steering blocks, and all black screws? Would this be the "newer" kit? Regardless, I'm in awe over the quality, and was more than happy when I saw the diffs were already built!
#4287
#4288
Originally Posted by jamescam
Yes, and I think I speak for everyone who bought a kit right before this version came out when I say "I hate you"
For all we know, Hudy could be coming out with an all new ride in 06 and they are dumping these chassis' into the kits to get rid of inventory....
#4289
ya, now i gotta buy a bmi, not that thats a problem since i will be beating all of you with the xray chassis
