Like Tree1Likes
Xray T1FK05
Old 10-24-2005, 02:50 PM
  #4261
rdub202's Avatar
Trader Rating: 19 (100%+)
try the link in his signature
rdub202 is offline
  #4262
BBSpence's Avatar
Trader Rating: 58 (100%+)
Originally Posted by zinger77
where can i find prs gears ?
http://www.teameamotorsports.com/cat...5e8eef82a6cbec
BBSpence is offline
Old 10-24-2005, 02:52 PM
  #4263
Originally Posted by HRCRACER123
Hey I wanna take all those silver screws out of my car. They strip out way to easy.
Does anyone know if they offer another screw kit for the FK'05. I think I heard something about black screws that were stronger? Anyone...
speedtech sells a titanium screw kit for it
http://www.speedtechrc.com/store/ebp...?catmainid=391
DOTMAN is offline
Old 10-24-2005, 02:56 PM
  #4264
rdub202's Avatar
http://www.rcscrewz.com/
sells a stainless steel set
rdub202 is offline
Old 10-24-2005, 03:37 PM
  #4265
HRCRACER123's Avatar
Trader Rating: 33 (100%+)
Hey which ones are better the titanium ones or the stainless steel?
HRCRACER123 is offline
Old 10-24-2005, 03:40 PM
  #4266
titanium is lighter and strong. I use them and haven't had a problem with them.
DOTMAN is offline
Old 10-24-2005, 04:05 PM
  #4267
hpipro321's Avatar
either one....the car is light enough if you go wit stainless
hpipro321 is offline
Old 10-24-2005, 05:23 PM
  #4268
protouring's Avatar
I have a 84 tooth spur with 60mm size foams what is a good gearing for 19t?
protouring is offline
Old 10-24-2005, 05:35 PM
  #4269
Hey guys I dont like the fact that the old silver screws kinda bonded to the carbon fiber in the chassis. Thats why alot are stripped out.
Would the titanium or stainless steels screws not do this?
Also the prices are $47 for the titanium and like $18 for the stainless steel. Is the titanium worth it?
Old 10-24-2005, 05:49 PM
  #4270
What I do to minimize the screw locking issue is put some ca on a Qtip and put a light coat of glue in the countersunk holes in the bottom of the chassis. I haven't had any problems since I started doing that to my cars. As far as the prices go, that's your call. If you go to santioned events which have a weight requirement, you'd probably have to add weight. The steel screws would probably be better because the extra weight is about as low as you can get it. For club racing, I like the weight savings that the Ti screws give me
DOTMAN is offline
Old 10-24-2005, 06:26 PM
  #4271
hpipro321's Avatar
THe titanium is not worth it at all go stainless
Old 10-24-2005, 10:10 PM
  #4272
nutfluff's Avatar
Default New to Onroad set-up
I am about to dip into the onroad scene and bring my T1R out to a parking lot race. I am in the process of setting it up using my HUDY set-up board..however I am having trouble lowering my rear ride height to 4.5mm. I have all the preload off the shocks and it won't go below 7.5mm. I have the shocks mounted on the middle of the rear tower and outside on the arms...what am I over looking?
Thanks in advance.
nutfluff is offline
Old 10-24-2005, 10:35 PM
  #4273
howard hudson's Avatar
Thanks in advance.
sounds like the lowwer spring purches are sitting to high on the lowwer shock mount (eyelet) I would get some FK ones and try that. why are you trying to get 4.5 ride hight for the rear ??? Thats to low for outside parking lots.
howard hudson is offline
Old 10-24-2005, 10:42 PM
  #4274
Speedo's Avatar
The spring retainers even in the Factory Kits, for some reason, still don't allow you to go much lower than 6-7mm. You have two options: a) if you want your car to look trick, pick up some Team Tamale spring retainers b) pick up a set of Associated spring retainers.
Either option will allow you to lower your ride height to where you want it.
www.teamtamale.com
Speedo is offline
Old 10-24-2005, 10:50 PM
  #4275
nutfluff's Avatar
the spring cups are locked down into the eyelets....just following a set-up sheet posted by Jim Bishop? from the Xray site...any suggestions?
nutfluff is offline
