Like Tree1Likes
Xray T1FK05
Old 10-18-2005, 05:24 PM
  #4156
hpipro321's Avatar
Just a Q but has anyone tried the aluminum front and rear uprights... are they worth it
hpipro321 is offline
Old 10-18-2005, 05:34 PM
  #4157
Hi,
I'm still building my fk'05 and have just finished bulding the steering assembly and placing the top deck on to the bulk heads. However I am missing two 3x6mm screws for the top deck. Will these screws appear in the later numbered bags ?
I can't remember whether there were 6 or 4 screws holding the top deck to the bulkheads when you first open the sealed box (I dissasembled and place all parts in snap lock bags). Or I may have used them in when attaching the bulkheads to the lower chassis, and in that case one of the earlier bags may have been short a couple of screws...
Just need to know if I need to add it to the list of things to buy when I next visit the hobby shop.
Thanks.
Phenochilus is offline
Old 10-18-2005, 06:09 PM
  #4158
there are spare parts in a bag....
i think you can find the spare screw there....
tsuiyuen is offline
Old 10-18-2005, 06:53 PM
  #4159
Front alu upright owners report that it bends easily. Take a look at the teamtamale ones. They say those are better.
Rear uprights: if you are going to buy them consider buying the ones with built in toe in. Teamdrivers like them (of course
cvt01 is offline
Old 10-18-2005, 07:11 PM
  #4160
hpipro321's Avatar
ty for the input ill check out the teamtamle ones
Old 10-18-2005, 08:23 PM
  #4161
lbckevin's Avatar
Trader Rating: 102 (99%+)
Nice spelling HPI pro
lbckevin is offline
Old 10-18-2005, 10:09 PM
  #4162
andrewdoherty's Avatar
Trader Rating: 48 (100%+)
Just a bump for teamtamale products. I race with Larry every sunday. He's always been a stand up guy to me. Not to mention I can vouch for the durability of his aluminum bits. Several racers at our track use his stuff and I have never heard of or seen a bent or broken part. From rookies to seasoned drivers. Just my .02 for a local friend.
andrewdoherty is offline
Old 10-19-2005, 01:07 AM
  #4163
jamescam's Avatar
+1! I picked up a full set of the shock collars and his aluminum C hubs and have been 110% statisfied! Now granted I don't actually race my pretty car but they look fast
jamescam is offline
Old 10-19-2005, 03:59 AM
  #4164
Thank you guys for the kind words. Makes all those extra hours after working my regular job worth it.
Just a note to all you Xray drivers out there, I will be offering a new motor mount that will allow about 1.5mm more forward motor adjustment for for anyone who needs to be able to run a larger pinion.
Also, the modified in line c-hubs are available in 3, 4.5, and 6 degree hard and medium compound plastic on a custom order basis.
Anyone intersted can email me through the website at http://www.teamtamale.com
teamtamale is offline
Old 10-19-2005, 04:08 AM
  #4165
Birky's Avatar
I've run them on an Evo2 with C-hub suspension for almost a year and haven't had a problem with them. I'm pretty sure they are the same ones.
Birky is offline
Old 10-19-2005, 06:01 AM
  #4166
teamgp's Avatar
If you're running stock, then it might be better to get the hard composite front c-hubs in order to save unsprung weight.
Here are a few XRAY forum threads discussing both:
http://www.teamxray.com/xforum/viewtopic.php?t=1491
http://www.teamxray.com/xforum/viewtopic.php?t=1277
teamgp is offline
Old 10-19-2005, 06:32 AM
  #4167
Originally Posted by teamgp
If you're running stock, then it might be better to get the hard composite front c-hubs in order to save weight.
I don't know that the weight of the c-hubs matters when you already have to add weight to the car to make it legal.
brianrice is offline
Old 10-19-2005, 06:37 AM
  #4168
teamgp's Avatar
True. But it won't be where you really want it for the slower corner speeds inherent to stock racing.
teamgp is offline
Old 10-19-2005, 07:06 AM
  #4169
HarshGuy's Avatar
..yea because we ALL make sure are cars are within legal weight limits even at club races where there is no tech
HarshGuy is offline
Old 10-19-2005, 08:07 AM
  #4170
Birky's Avatar
Would the lighter weight be better for the suspension?
Birky is offline
