Like Tree1Likes
Xray T1FK05
Old 10-17-2005, 02:51 PM
  #4141
Any tires chunk when you hit something, or dont have your body cut out with proper wheel well clearance. No companys tire will chunk any more or less then another...
Bobby Flack is offline
Old 10-17-2005, 02:52 PM
  #4142
andrewdoherty's Avatar
Trader Rating: 49 (100%+)
I am just sharing my experience. And I hit plenty of stuff.
andrewdoherty is offline
Old 10-17-2005, 03:06 PM
  #4143
There was a time when the Jaco wheels were very brittle. That could be part of what you were having problems with.. That problem has been solved now.
Old 10-17-2005, 03:21 PM
  #4144
hpipro321's Avatar
.... jaco foams need to be taken care of even after the fix
hpipro321 is offline
Old 10-17-2005, 04:29 PM
  #4145
berger's Avatar
Originally Posted by Michal101
berger,
I had the same problem, but I purchased a set of lowered spring collars that lower it about 2 mm from Team Tamale. You can check out the lowered shock collars and his other quality stuff at http://www.teamtamale.com/
He has a bunch of other great Xray optional parts.
Mike
That looks just like what i want, but i cant afford $53 inc shipping for four!
berger is offline
Old 10-17-2005, 05:22 PM
  #4146
kerry's Avatar
when you cut down the jacos to your specific size just glue the outside walls with alittle ca, never chunked a tire since
kerry is offline
Old 10-17-2005, 06:57 PM
  #4147
Speedo's Avatar
Originally Posted by mtc3od
Just got back from my lhs and saw the new xray 05 boxes. The sticker on the front said that the new kit had both a 2.5 mm and 3.0 mm chassis.
Do you have a number for your LHS? I have been trying to get ahold of two FK05 kits but nobody has them in stock, and according to RC Screwz, RC America has said 2-3 weeks for the next shipment.
Josh
Speedo is offline
Old 10-17-2005, 06:58 PM
  #4148
Speedo's Avatar
Dude, didn't you see that several people have mentioned recently that the TC3/4 spring retainers also work?
Speedo is offline
Old 10-17-2005, 07:00 PM
  #4149
Josh
T and T Hobbies 972-633-2470
Chris
mtc3od is offline
Old 10-18-2005, 07:04 AM
  #4150
Scho's Avatar
Got a quick question.
Reading through the manual building my new 05 got to the length of the turnbukles that go from the hubs to the steering assebly.
It says:
Left 62mm
Right 60.5mm
and they both have scale drawrings. so i mesured them up to the drawring after i messured them. left drawring is shorter than the right drawring!
seems the drawrings have been swapped aroung or somthing?
Scho is offline
Old 10-18-2005, 08:34 AM
  #4151
berger's Avatar
Yeah, but i need the bling I can probably pinch a friends TC4 retainers until the Team Tamale ones arrive, he pm'd me with a lower shipping price due to the items being tiny that i wanted
berger is offline
Old 10-18-2005, 11:16 AM
  #4152
It says:
Left 62mm
Right 60.5mm
The left should be the longer one..
Old 10-18-2005, 01:02 PM
  #4153
teamgp's Avatar
Another update on the one-way foam/carpet setup for those interested:
http://www.teamxray.com/xforum/viewt...?p=25562#25562
Not a whole lot to share, just some info on rear anti-roll bar use and driving style recommendations for the setup.
teamgp is offline
Old 10-18-2005, 01:04 PM
  #4154
dado11g's Avatar
hey bobby, do you have any kind of setup i could use at rc screws with the stock chassis and upper deck on parma cyan/magenta? i usually have a bad push when running stock or 19t.
dado11g is offline
Old 10-18-2005, 01:05 PM
  #4155
teamgp's Avatar
It says:
Left 62mm
Right 60.5mm
Thanks for catching that. I'll pass it along to the documentation team.
teamgp is offline
