Old 10-11-2005, 02:38 AM   #3991
Scho's Avatar
Send a message via MSN to Scho
If you get a hit to the side wont it rip the whole thing right off?, looks nice and tidy though
Scho is offline   Reply With Quote
Old 10-11-2005, 03:04 AM   #3992
SchuMi2's Avatar
Trader Rating: 34 (100%+)
The endbell is a further 3/8" out past the cap, so in a way it gives it a little protection You could mount the ESC in a little closer to the belt and it would be less exposed. I have had a couple of hits in the side and no problems so far.
SchuMi2 is offline   Reply With Quote
Old 10-11-2005, 09:10 AM   #3993
HRCRACER123's Avatar
Trader Rating: 33 (100%+)
I run on high bite carpet. The car handles good. I was wondering if I should run sway bars. Wouldn't that give me more transition speed and keep the car flatter?
Do you guys run sway bars on carpet?
HRCRACER123 is offline   Reply With Quote
Old 10-11-2005, 09:26 AM   #3994
kerry's Avatar
it would give you less chassis role, but front or rear roll bar? what is your car doing. ie. oversteer in mid corner ect.. more info we can help you out better.
kerry is offline   Reply With Quote
Old 10-11-2005, 09:51 AM   #3995
The car handles good. I am just looking to get a little more transition speed.
Old 10-11-2005, 09:54 AM   #3996
Default RCC Shocks
Hi Guys,
Just a quick note to let you know that we have the new shocks in stock and available. They fit all Xray cars. Part number is #903164 for the fronts and #903165 for the rears. They come pre build and ready to go. Check with your LHS.
Serpent USA
Paolo M is offline   Reply With Quote
Old 10-11-2005, 10:23 AM   #3997
teamgp's Avatar
Originally Posted by Bobby Flack
Phenicoulus... Chances are the arm just needs to be filed or dremeled down a little bit. I also use a oversized reamer (3.05MM) on all the arms to make sure that the hingepins arent causing the problem. When I tighten up the arm mounts I always pull the arm towards the mount to help get everything lined up better.
I use the Kose 3.03mm reamer.
Guy Hood
Sponsored by: Team XRAY / Team RC America / RB Products USA
/ Twister Tires USA / Maxy's Mods & Fuel / Parma PSE / Zubaks
Un-sponsored Shoutout: NexusRacing.com
*** 301 Raceway is my home away from Home ***
teamgp is offline   Reply With Quote
Old 10-11-2005, 10:31 AM   #3998
teamgp's Avatar
Most team drivers use a a 1.0mm front anti-roll bar for foam/carpet racing. I use a front anti-roll bar, but I haven't tried using a rear one yet.
Guy Hood
Old 10-11-2005, 01:53 PM   #3999
Jimmy Morris's Avatar
Originally Posted by hpipro321
ditto
I had the arm 100% out of the car holdnig the hinge pin and it was a super tight fit. Someone else I know had the same thing happen to his as well.
www.superiorhobbies.com
Jimmy Morris is offline   Reply With Quote
Old 10-11-2005, 02:07 PM   #4000
Chris08527's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Paolo M
Hi Guys,
Serpent USA
i heard that you need to use the rear serpent shocks on both the front and rear of the x-ray ????
so you need to buy two pairs of rear shocks???
"Hello How 'bout that ride in? I guess thats why they call it Sin City." Alan Garner~"I play the drums, I'm good as hell" Richie Rich
Chris08527 is offline   Reply With Quote
Old 10-11-2005, 02:10 PM   #4001
DougC's Avatar
R/C Tech Charter Subscriber
That's what I've read as well. It's my understanding that the front RCC shocks are shorter that the rears, could be wrong. This is what was posted by acutts about the shocks: "Anyone want to get the best shocks possible for the X-ray .... do yourselves all a favour and buy the new Serpent shocks (U need 2 sets rears 903165). They fit directly on and are the smoothest best working shocks I have ever seen. It took me exactly 4mins to fill with oil and assemble 4 shocks with no air bubbles and exactly the same rebound. They are just awesome."
DougC is offline   Reply With Quote
Old 10-11-2005, 03:38 PM   #4002
ChrisP's Avatar
Shock lengths on the Xray cars T1 Evo2 and later were all equal length...
The T1 used Serpent shocks F& R and were unequal length.
ChrisP is offline   Reply With Quote
Old 10-11-2005, 03:45 PM   #4003
John Tag's Avatar
Trader Rating: 42 (100%+)
I'll have my new shocks tommorow
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,[email protected]
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 10-11-2005, 04:33 PM   #4004
axel's Avatar
Who here owns the Adj. top deck? If I were to get it what should I expect?
axel is offline   Reply With Quote
Old 10-11-2005, 05:09 PM   #4005
That's rigth...... Front and rear of the Xray are the same as the rears.
They come in individual packs, so you just need to get to set of rears and you are set
Xray T1FK05 $100.00 Charles R/C Items: For Sale/Trade 2 04-25-2006 10:51 AM
F/S: Xray T1FK05 ewippler R/C Items: For Sale/Trade 12 12-09-2005 04:03 PM
WTB: Xray T1FK05 ewippler R/C Items: Wanted to Buy 4 05-06-2005 06:40 AM
