Like Tree1Likes
Xray T1FK05
Old 10-10-2005, 01:28 PM
  #3961
Trader Rating: 31 (100%+)
Originally Posted by Andrew_Carter
Xray CF is wack!!
I broke 3, 2.5mm chassis,2 on the front end ,and 1 on the battery slot!
Quick fix,buy an RDX! 2.9MM chassis baby!! not gonna break that beauty!
Why all the hate?Like Kevin said, its your fault obviously. Bandwagoneer.
racenut123 is offline
Old 10-10-2005, 02:14 PM
  #3962
L.Fairtrace's Avatar
Trader Rating: 24 (100%+)
We have a whole gaggle of xrays at our local track and I have never seen a chassis split in any place. And believe me some of them are putting the bumpers to the test.
L.Fairtrace is offline
Old 10-10-2005, 02:47 PM
  #3963
Chris08527's Avatar
Trader Rating: 16 (100%+)
fixed my shock prob, bottom cap was not on properly, not a big fan of the whole shock design
trying to mount the electronics using a KO 2343, KO302 and a novak GTX
the big cap on the GTX can really get in the way and i really dont want to put the reciever on the servo also have to put the PT somewhere
anyone have any suggestions or pics of everything mounted in there ride???
Chris
Chris08527 is offline
Old 10-10-2005, 03:16 PM
  #3964
Steve Bahnatka's Avatar
here ya go...
Steve Bahnatka is offline
Old 10-10-2005, 03:20 PM
  #3965
Lil B' you coming to Horsham this weekend?
Not to bust you but that is none of the electronics he wanted to see in the car. Nice placement of the epic logo.
Old 10-10-2005, 03:21 PM
  #3966
raving-monkey's Avatar
Chris
i used to run the same setup as you before i fired my GTX...
i had the powercap stuck to the top deck...but you can mount the esc further into the centre (towards the belt) and mount the cap just infront of it..and the reciever next to the esc (inbetween the esc and servo)
raving-monkey is offline
Old 10-10-2005, 03:51 PM
  #3967
eforer's Avatar
you can use 2 smaller 4700 mf caps in parallel, its a bit easier to package. You can stick your PT on the back of the servo or on top too.
eforer is offline
Old 10-10-2005, 03:59 PM
  #3968
yeah, i should be there...I know, but there probably similar in size.... oops, did i accidently put that in the pic? LOL
Old 10-10-2005, 04:01 PM
  #3969
Chris08527's Avatar
Originally Posted by Little Bahnatka
here ya go...
thanks steve
doesnt have to be the same just looking for some ideas???
how did you run the wires off the esc so you did not have to jump the + off the motor???
chris
Old 10-10-2005, 04:35 PM
  #3970
hpipro321's Avatar
or you can stick your pt on the side of your servo
hpipro321 is offline
Old 10-10-2005, 05:06 PM
  #3971
thanks steve
chris
i just made a "Y" out of the wire.... heres a pic with out shrink
Old 10-10-2005, 05:44 PM
  #3972
Chris08527's Avatar
thanks steve that helps me out i think that is what i will do to keep it nice and neat
Old 10-10-2005, 06:12 PM
  #3973
anytime....
Old 10-10-2005, 06:19 PM
  #3974
IRISH's Avatar
Default THNX
Thanks to R.Burch for hooking me up with a chassis after my idiotic meeting with the pipe in the last heat.It got me to my main,did not do well (crappy driving skills,not being able to adapt to the chassis change) but I finished and had a great time.Thnx again----"IRISH"
IRISH is offline
Old 10-10-2005, 06:56 PM
  #3975
Hi I just bought the fk05 and am new to xrays as I have only played with tamiyas.
I've started building this chassis and was wondering how to remove the binding in the rear a arms. The tigher I screw them into the bulk heads the more they bind. Will this binding loosen up after a few runs or will I need to do something about it ?
Thanks.
Phenochilus is offline
