Like Tree1Likes
Xray T1FK05
Old 10-09-2005, 08:00 PM
  #3946
sharkman's Avatar
Trader Rating: 18 (100%+)
Thanks, will try that.
sharkman is offline
Old 10-09-2005, 08:02 PM
  #3947
Dennis Rabanes's Avatar
Originally Posted by centax error!
I want to know the effect of doing so...
- adding spacer on the front hinge pin holder on the front bulkhead (arms sweeping forward) ?
-adding spacer between the steering block and steering rod?bumpsteer?
-using a Hard compound for the rear arms? reduce rear traction?
- using a soft compound for the front c-hub? increase front traction?
-using -1 wheel axle on the front and thus reducing front track width by 2 mm? car rotates better?
-using +1 wheel axle and thus increasing front track width by 2 mm?
-shock rebound of 30 % - 50 % ?
Anybody can elaborate? I'm intersted too
Dennis Rabanes is offline
Old 10-09-2005, 08:23 PM
  #3948
sharkman's Avatar
No luck on ebay, do you have a specific link?
sharkman is offline
Old 10-09-2005, 09:50 PM
  #3949
HRCRACER123's Avatar
Trader Rating: 33 (100%+)
I was driving my car today and got tangled up with someone at the track and I hit a board. After the race I examined my car to find out that the nose of the chassis was tearing apart. Out of those 3 screws in the front 2 of them went through the carbon fiber and the chassis is spliting.
I ca glued it too. I was told by the owner of the hobby track that this has happened to about 3 other people. He said that X-ray puts the srews too close to the front causing it to split by not giving it enouf support. I think he is right.
Has this happened to anyone else?
HRCRACER123 is offline
Old 10-09-2005, 09:55 PM
  #3950
S-T-R-l-K-E-R's Avatar
YES this has happened to me and another guy at my local track.
now i am using the 2mm chassis and the chassis is hidden under the bumper's chassis guide. guide is 2.5 mm deep so i have .5 clearance fron the bumber to the start of my chassis
S-T-R-l-K-E-R is offline
Old 10-09-2005, 11:18 PM
  #3951
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Y'now, I have a Kyosho TF4R and its almost like an XRay T1 in every way except the bumper attaches to a small graphite T-plate which then attaches to the chassis. I never knew why. I thought it was an annoying design meant to get more parts sales from Kyosho owners because the thing costs $10 everytime there was a bad hit on the bumper.
However after hearing about this, I now understand the wisdom of Kyosho.
Don't get me wrong I still love my FK05!!
YR4Dude is offline
Old 10-09-2005, 11:37 PM
  #3952
JohnMatrix's Avatar
Also, the next time, dont over tighten the screws. This will prevent it in most cases. Get them snug not tight.
JohnMatrix is offline
Old 10-10-2005, 12:40 AM
  #3953
axel's Avatar
Well, I decided to sell my Xray so if you haven't noticed my signature there it is.
axel is offline
Old 10-10-2005, 09:42 AM
  #3954
Alex C's Avatar
Trader Rating: 50 (100%+)
Hey Guys,
What some of the Xray team drivers have been doing is...not installing the center screw on the lower bumber holder, in addition to using CA in the tapered screw's & around the front edge.
I hope this helps!!
Best Regards
Alex
Alex C is offline
Old 10-10-2005, 10:18 AM
  #3955
Scho's Avatar
Ive seen tons of people breaking chassis, the qyuality has gone down there for sure.
Scho is offline
Old 10-10-2005, 10:34 AM
  #3956
ChrisP's Avatar
Wow...we have 2 dozen FK05's running regular at our local track andIhave yet to see a broken chassis??
make sure that screws are tightened properly....securely, but not ovetight....
If too loose it creates leverage that will make it easier for screws to pull through...
ChrisP is offline
Old 10-10-2005, 11:23 AM
  #3957
teamgp's Avatar
Originally Posted by Chris08527
any shock help???
Take a look at the shock building/maintenance tips post in the XRAY forum FAQ thread. Its a lot to read, but doesn't take long once you understand each step.
teamgp is offline
Old 10-10-2005, 11:34 AM
  #3958
Andrew_Carter's Avatar
Xray CF is wack!!
I broke 3, 2.5mm chassis,2 on the front end ,and 1 on the battery slot!
Quick fix,buy an RDX! 2.9MM chassis baby!! not gonna break that beauty!
Andrew_Carter is offline
Old 10-10-2005, 01:11 PM
  #3959
lbckevin's Avatar
Trader Rating: 106 (99%+)
The problem is not the chassis. Its you.
Try staying off the boards, not hitting wall or other drivers and you will not have a problem. Did you seal the chassis with CA ?
Invest in some pratice time before you start bashing products.
lbckevin is offline
Old 10-10-2005, 01:12 PM
  #3960
lbckevin's Avatar
HMMMMMMMMMMMMMMM....
Do you know who manufactures the carbon fiber ?
Same company makes them for both cars and the same specs....
Not the fault of the CF, just the driver.
lbckevin is offline
