Like Tree1Likes
Xray T1FK05
Old 10-07-2005, 11:38 AM
  #3916
DougC's Avatar
Originally Posted by acutts
Anyone want to get the best shocks possible for the X-ray .... do yourselves all a favour and buy the new Serpent shocks (U need 2 sets rears 903165). They fit directly on and are the smoothest best working shocks I have ever seen. It took me exactly 4mins to fill with oil and assemble 4 shocks with no air bubbles and exactly the same rebound. They are just awesome.
Mine are on the way. Buggers sure are pricey though......
DougC is offline
Old 10-07-2005, 01:47 PM
  #3917
VoodooDaddy's Avatar
Originally Posted by BHenderson
Does anyone make a foam car stand for the FK05?
Why you dont have one yet
Or do you
VoodooDaddy is offline
Old 10-07-2005, 03:15 PM
  #3918
chris moore's Avatar
Trader Rating: 96 (99%+)
Default Will there be an FK06??
I took a break from the hobby this yr but I'm looking to get back in by January; so has anyone heard if Xray will be putting out a new model next yr?
Chris
chris moore is offline
Old 10-07-2005, 04:21 PM
  #3919
motorhead's Avatar
anyone have any good set ups for the track in md at mims
motorhead is offline
Old 10-07-2005, 05:55 PM
  #3920
Speedo's Avatar
Where did you get them from?
Speedo is offline
Old 10-07-2005, 07:29 PM
  #3921
DougC's Avatar
Serpent USA directed me to MR. Gift & Hobbies. Thier phone number is 305-525-5244
DougC is offline
Old 10-07-2005, 09:22 PM
  #3922
1armed1's Avatar
Trader Rating: 79 (100%+)
Exactly what size wrench does the screws in the top deck and bottom of the chassis take.
2.0 is the only thing I have that fits in there and is somewhat snug, problem is I have stripped most of the screws.
Any one know where I can buy some good replacement screws other than the high dollar kit from xray?
Dayton
1armed1 is offline
Old 10-07-2005, 10:54 PM
  #3923
jamescam's Avatar
I used RC Screwz in my XRay and have been very happy. Not only do they add a little extra bling I have never had one strip out.
jamescam is offline
Old 10-08-2005, 02:19 AM
  #3924
Default screws
if you go to a bolt shop buy the black ones high tensile that is what we have done
jeff19 is offline
Old 10-08-2005, 03:41 AM
  #3925
Check out this link http://www1.mscdirect.com/CGI/N2SRHI?PMSECT=0002006708 This is where i purchase all my screws. Unless you want to spend top dollar for titanium screws, you can buy them by the box of 100 for $5-$7.
teamtamale is offline
Old 10-08-2005, 04:47 AM
  #3926
polesitter61's Avatar
If you coat the beveled part of the CF with CA glue where the screw touches the chassis or upper deck then they will not be so hard to get out. When they get tight it's because the get stuck in the CF, not the aluminum.
polesitter61 is offline
Old 10-08-2005, 05:00 AM
  #3927
hpipro321's Avatar
you can do that or if your using lock tight dont use it
hpipro321 is offline
Old 10-08-2005, 05:56 AM
  #3928
1armed1's Avatar
So is the 2.0mm wrench the right one?
1armed1 is offline
Old 10-08-2005, 06:20 AM
  #3929
the_barbarian's Avatar
can someone help with setup I just want a bit more rear grip the back of the car is very touchy if you dont white knuckle the controller the ass slipps out
if I run 42r on the front and 37r on the rear I get it but I would prefer to run 42r on front and 40r on rear
I was thinking of using 42f on the front maybe that would help
here is my setup
http://www.teamxray.com/xforum/xform...9&setup=t1fk05
thanks in advance
the_barbarian is offline
Old 10-08-2005, 10:57 AM
  #3930
Eric Gebhard's Avatar
here is my setup
thanks in advance
After looking at you setup I would suggest increasing the front droop a bit. This will allow for more weight transfer to the rear. Remember with droop the front-end effects the rear and the rear-end effects the front. The other thing you might try, if you havenít all ready, is shorting your wheelbase. This may sound counter intuitive but it will put more weight over the rear wheels thus stabilizing the rear end. Hope this helps.
Eric
Eric Gebhard is offline
