Like Tree1Likes
Xray T1FK05
Old 10-01-2005, 08:52 PM
  #3826
howard hudson's Avatar
Originally Posted by axel
ps: I might trade it for a 415 (wierd huh )
Now thats just CRAZY TALK !!!!!!
howard hudson is offline
Old 10-01-2005, 08:56 PM
  #3827
dado11g's Avatar
heres mine http://rctech.net/forum/showthread.php?t=85876 . crazy huh?
dado11g is offline
Old 10-01-2005, 09:03 PM
  #3828
axel's Avatar
it's not even an ms just has the lwt suspension and TONS of spares.
axel is offline
Old 10-01-2005, 09:13 PM
  #3829
I think you and this guy have something in common !!!
Old 10-01-2005, 09:19 PM
  #3830
axel's Avatar
he wants a 415 too?
i actually might wait for someone just to trade an msx with me...i know that's what i'll probbaly end up doing anyways.
BUT THE XRAY IS STILL MINE.
axel is offline
Old 10-01-2005, 09:20 PM
  #3831
he wants a 415 too?
Old 10-01-2005, 09:28 PM
  #3832
teamgp's Avatar
Here's an update on my FK05 one-way foam/carpet setup project for those interested.
teamgp is offline
Old 10-02-2005, 09:28 AM
  #3833
Default New Serpent shocks for T1 FK'05
Acutts (or someone else),
You wrote (page 126) about the new serpent shocks. Are Xray pistons (non-adjustable) and springs compatible ?
Thanks fot the answer.
Blin is offline
Old 10-02-2005, 10:39 AM
  #3834
acutts's Avatar
Has anyone tried the 0.75mm lower suspension holders? Can you run them front and rear or are they just for the rear of the car?
acutts is offline
Old 10-02-2005, 11:22 AM
  #3835
Blin is offline
Old 10-02-2005, 11:52 AM
  #3836
teamgp's Avatar
You can use them on either end. Team drivers are frequently using them now to lower the rear roll center half as much than if you moved the suspension holder screws to the lower holes in the bulkheads. Some actually use them only for the rearward two holders of the rear pins to provide .75 degrees of anti-squat. If you wanted to raise your front roll center slightly, you could use the new suspension holders in the top holes on the front bulkheads.
teamgp is offline
Old 10-02-2005, 01:05 PM
  #3837
stormperson's Avatar
In vegas i used them in the front to add anti dive while not changing my roll center. You can use them all around in the car...
stormperson is offline
Old 10-02-2005, 01:27 PM
  #3838
Hi all ..
The indoor seizoen is comming .. now I need a good setup for a indoor track .. 19t .. Anyone ?
-hugo
hugovdb is offline
Old 10-02-2005, 02:06 PM
  #3839
acutts's Avatar
The springs are perfectly compatible with serpent. The pistons Im not sure I use the serpent ones... the shocks come with 3 hole installed and then in the package u get 1 and 2 hole as well.
Won my first meeting out with the new shocks ... FTD, fastest lap and 2 final wins ...
L8r......
acutts is offline
Old 10-02-2005, 02:57 PM
  #3840
Thanks for the answer acutts.
I received my T1 FK '05 last week. I started the building with shocks... I always start the building of a new kit with shocks.
But with xray shocks, what a deception ! First of all, they look not so pretty than the rest of the car (not so crucial, I agree). Then, the rebound issue : almost impossible to have 4 equal shocks.
These Serpent shocks look great and work very well (according to your last results). So, I think I'm gonna try them.
Cheers.
Blin is offline
